Evac System Problem
#245761
03/07/09 08:13 AM
03/07/09 08:13 AM
Posts: 6,295 U.S.
moparniac
U.S.
well i went to install the headers today and the pipe nipple was hitting the bottom of the floor...... and thats without the screw on piece for the tube.... looks like some sort of baffle inside there..... can i just straight hook the tubing right onto the nipple and cut the nipple down some and clamp it on??? also can evac e body guys post pics of there setups.... it was welded in per mr gasket directions...
Mopar Performance
Re: Evac System Problem
[Re: moparniac]
#245762
03/07/09 10:05 AM
03/07/09 10:05 AM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
you have to have the valve its a one way check valve without it the header will put pressure in the motor.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: cudabunch]
#245764
03/07/09 10:34 AM
03/07/09 10:34 AM
Posts: 6,295 U.S.
moparniac
U.S.
no they are tti headers with no slip on collector.. they are aftermarket full floorpans.... not sure if that matters....
Mopar Performance
[Re: moparniac]
#245765
03/07/09 10:46 AM
03/07/09 10:46 AM
Posts: 1,217 Wellington, FL
cudabunch
Wellington, FL
That isnt good.I guess I would put another one on the side which gives you the most clearence and weld the one you have closed. Sorry
[Re: BobR]
#245767
03/07/09 11:15 AM
03/07/09 11:15 AM
Posts: 6,295 U.S.
moparniac
U.S.
what about threading the nipple down deeper and cutting off the excess nipple or getting hot with a welder and bending the nipple some ???
Mopar Performance
[Re: moparniac]
#245768
03/07/09 11:25 AM
03/07/09 11:25 AM
cudabunch
Wellington, FL
If its hitting now without the valve on it, I dont see how it would fit. Cap it and get two more nipples and put them to the outside so the line from the vavle cover doesnt have to travle through the header area.
[Re: Quicktree]
#245770
03/07/09 11:37 AM
03/07/09 11:37 AM
Quicktree
