Front End Tire Wear #2456834
02/24/18 06:23 PM
02/24/18 06:23 PM
MarkZ Offline OP
Worthy
MarkZ  Offline OP
Worthy
I've had an issue for some time now with the front end of my car wearing the outsides of the tires. I've had it aligned twice in the last two years, yet the wearing is getting worse. From the printout I got comparing the two previous years camber and caster have stayed the same, so I think it's more a less a problem of not being aligned to a spec that doesn't cause tire wear. Problem is, I have no idea what values to ask for and it's obvious whatever factory spec is it isn't working.
Need some advice before replacing the front tires again... Thanks guys...
Re: Front End Tire Wear [Re: MarkZ] #2456861
02/24/18 07:01 PM
02/24/18 07:01 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
I think for one thing, since camber/caster are exactly the same, the shopmonkey didn't touch anything but the tie rods on the second "alignment".
Then, camber should be slightly negative. Certainly not positive, that's for old cars running diagonal tires.
I would also be looking at worn/soft bushings like idler arm, strut rods or in the upper/lower control arms.
Re: Front End Tire Wear [Re: MarkZ] #2456942
02/24/18 09:15 PM
02/24/18 09:15 PM
Colorado
Bob J Offline
Bob J  Offline
Colorado
After you check for worn parts find a race shop to do the alignment. You will pay more but they will and set it correctly.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS
68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam
65 Chrysler 300 Convert. project
57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son
2003 Dodge Dakota R/T "DEAD"
Re: Front End Tire Wear [Re: MarkZ] #2456943
02/24/18 09:17 PM
02/24/18 09:17 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
What do the printouts show?
Re: Front End Tire Wear [Re: MarkZ] #2456948
02/24/18 09:39 PM
02/24/18 09:39 PM
MarkZ Offline OP
Worthy
MarkZ  Offline OP
Worthy
Sorry, for some reason the image of the printout didn't embed properly in the original message - I just fixed it.
All the parts on the front end are new. Moog bushings/joints/tie rods & sleeves/etc. Firm Feel T bars, and Firm Feel upper control arms.
It was a race shop that both alignments.
Re: Front End Tire Wear [Re: MarkZ] #2456973
02/24/18 10:29 PM
02/24/18 10:29 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Idler arm good? No slop in the torsion bar bushings?
Angry white pureblood male
Re: Front End Tire Wear [Re: MarkZ] #2457005
02/24/18 11:08 PM
02/24/18 11:08 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I'd question the equipment was installed on the car properly. It doesn't take much toe to burn off rubber.
I would be running a tape measure to see if the toe is in the ballpark
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Front End Tire Wear [Re: BigBlockMopar] #2457011
02/24/18 11:15 PM
02/24/18 11:15 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
It sure seems like a "Toe and Go" alignment. Very few newer cars have camber and caster adjustments.
.28 degrees total toe on a 25.5" diameter tire is 1/8" toe.
I would suggest on a car that gets a good amount of street miles:
.5-.25 negative camber.
3.5 to 2.5 positive caster
.120 degrees total toe-in ( 3/32")
you can easily gain positive caster and negative camber, if there is inward adjustments on the rear cam eccentrics on BOTH sides of the car.
FYI .075 deg total toe on a 25.5" tire is 1/16" toe in.
Convert Toe Angle to Inches:
https://robrobinette.com/ConvertToeDegreesToInches.htm
Re: Front End Tire Wear [Re: MarkZ] #2457072
02/25/18 12:26 AM
02/25/18 12:26 AM
central IL
myduster360 Offline
myduster360  Offline
central IL
Excessive Toe-in is causing the outside edges to wear, not the Camber nor Caster.
That .6 degrees is WAY OUT, nearly 2x.
.28 degrees total Toe-in is perfectly fine now but what was the Toe in the previous years alignments?
1972 Swinger 3.6L Pentastar
Diablo CMR tuner
Re: Front End Tire Wear [Re: MarkZ] #2457293
02/25/18 01:54 PM
02/25/18 01:54 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I'd agree with the previous replies on toe. The fact that they are a "race" shop and didn't suggest better specs to you would make my suspicious of them. If they are giving you free or low cost adjustments to get it back where it should be, then you might stick with them, otherwise, I'd look for a new place.
Ditch the 5th Avenue specs for '05 Mustang GT specs.
Re: Front End Tire Wear [Re: MarkZ] #2457328
02/25/18 03:13 PM
02/25/18 03:13 PM
So Cal
So Cal
I see .4 more positive caster on left side. Ok that may be for road crown.
But why not then run .8 negative camber on left side to equal things up? Is the .8 negative camber on right side also for road crown?
Is the tire pictured above the left front?
Re: Front End Tire Wear [Re: autoxcuda] #2457368
02/25/18 04:35 PM
02/25/18 04:35 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Mark, That's what you're looking at there. They only adjusted the toe. Sorry but thats what happened.
That camber is out of spec even for the original bias & cross ply tires.
eg from 1968 Plymouth Service Manual.
Left: +0.25 to +0.75, Right: 0 to +0.5 degrees
With modern radial tires - especially performance tires - they will want some negative camber. (Competition tires all have recommend range you can get from the manufacturer.) If you have nothing else to go by, based on tire wear with +.8 on the one side, and assuming radial construction, go for -.5 camber both sides as a starting point.
Alignment changes must be done in sequence. The factory service manuals lay this out very well. This reduces the number of iterations to get everything in spec.
1. Adjust ride height.
2. Adjust Camber
3. Adjust Caster
4. Adjust Toe
Re: Front End Tire Wear [Re: Mattax] #2457386
02/25/18 05:26 PM
02/25/18 05:26 PM
So Cal
So Cal
2. Adjust Camber
3. Adjust Caster
4. Adjust Toe
Oh cr@p !
I didn't notice it had POSITIVE .8 degrees of camber.
That BS. Have them fix that at the very least.
Re: Front End Tire Wear [Re: MarkZ] #2457395
02/25/18 05:49 PM
02/25/18 05:49 PM
Kirkland, Washington
Pacnorthcuda Offline
I think the shop was lazy and their system isn't working with correct numbers. No way is that .8 positive camber on the right front "in spec"
I would go back and demand .5 Negative.
Re: Front End Tire Wear [Re: Pacnorthcuda] #2458622
02/27/18 11:23 PM
02/27/18 11:23 PM
IN
ahy Offline
ahy  Offline
IN
Toe looks OK. Agree it needs negative camber, especially with radials. Positive camber will wear the outsides. You need between .5 and .75 degree negative camber and as much positive caster as you can get up to 5 degrees.
Also, you really need to tell the shop what you want. A good and friendly shop will try to dial it in as requested. At least that is my experience. Otherwise, most do not know what to do with a classic T bar car.
