How hard to remove just the engine? #2456567
02/24/18 10:30 AM
02/24/18 10:30 AM
NH
N
NHCharger Offline OP
N
NH
I have always removed engine and tranny as one unit. But now just need to work on the engine. How difficult is it to remove just the engine and would I really save any time in the long run??
My Dad always told me, when setting goals " avoid disappointment, aim low".
Re: How hard to remove just the engine? [Re: NHCharger] #2456569
02/24/18 10:41 AM
02/24/18 10:41 AM
Minn
SportF Offline
SportF  Offline
Minn
To me, its the only way to do it. You do have to support the transmission, but pulling them out together is a paint scratching proposition.
In addition, when pulling them out together, you need a lot of ceiling height which some places don't have.
I unbolt the intake manifold, and have made a "lifter" whose pickup point is about 2" above the cam in the valley. I have had many engine changes over the years and don't even have to take the hood off.
Re: How hard to remove just the engine? [Re: NHCharger] #2456572
02/24/18 11:15 AM
02/24/18 11:15 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
With an automatic transmission it's easy. With a standard shift, not so easy.
Re: How hard to remove just the engine? [Re: NHCharger] #2456582
02/24/18 11:41 AM
02/24/18 11:41 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
For many years as profession, as well as hobby, have taken engines out the top in almost all cases. That whole take it out the bottom thing is a waste if you're just doing engine.
Re: How hard to remove just the engine? [Re: NHCharger] #2457059
02/25/18 12:11 AM
02/25/18 12:11 AM
Ontario, Canada
500ciBee Offline
500ciBee  Offline
Ontario, Canada
I just pulled the engine in my Bee today. I left the trans in the car. (auto) I don't have a lift so my car is on jack stands so I can get under it. I don't think my engine hoist would be able to lift both high enough to clear the fenders. The only tough bolt for me was the passenger side trans bolt slightly below the head. I needed a bent handle adjustable head ratchet to get that one. Everything else is fairly easy.
1970 Super Bee prostreet. 383, SMR 727, Dana 60 4:88. Building a 512 low deck.
Re: How hard to remove just the engine? [Re: NHCharger] #2457129
02/25/18 02:38 AM
02/25/18 02:38 AM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
I pull the trans and then the motor. That way less chance of tearing the paint up. When I put the last one in the dart I went in from the top with the hood on then trans after
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: How hard to remove just the engine? [Re: NHCharger] #2457132
02/25/18 02:49 AM
02/25/18 02:49 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
just pulled mine in the charger, left the trans in the car, put 2 bolts on the front side of the bellhousing & put a cross bar to hold the trans up.
Re: How hard to remove just the engine? [Re: NHCharger] #2457146
02/25/18 03:56 AM
02/25/18 03:56 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I think I may have pulled one or two ever with the trans attached, not much fun by yourself. I've done probably 100s just engine and leaving trans in... hardest part is getting to some of the bellhousing bolts, but not that difficult in older cars. If it's a manual trans, I would pull the trans out first to save a lot of hassle later on.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: How hard to remove just the engine? [Re: NHCharger] #2457156
02/25/18 04:15 AM
02/25/18 04:15 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
I had a terrible time pulling the 4-speed first on my Bee. The top 2 transmission to bellhousing bolts were an absolute nightmare. So I started pulling and installing them together. I don't remember the top two bolts being such a complete pain when I had a factory bell on it.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: How hard to remove just the engine? [Re: NHCharger] #2457283
02/25/18 01:36 PM
02/25/18 01:36 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
In the old days before # matching, the top radiator support was cut out, bolted back in with straps. Much easier to get engine-trans out and back in together.
If you have a lift, pull separately. I just finished rolling around on the floor yesterday pulling the trans from my Ram Van, every muscle and joint is killing me, getting to old for this. Bad part, I gotta rebuild and put it back! But not for awhile. LOL dakota frown
