What clutch for t56 with higher hp in quicktime bell?
#2452600
02/16/18 03:37 PM
02/16/18 03:37 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
What clutch are people running with t56s behind higher hp gen 3 hemis using quicktime bells?
I know they require a 130t flywheel and recommend a 10.5 gm clutch, but what about people running engines like a hellcat with 700+ hp? My understanding from my research is a twin disc will not fit... but I would think a smaller 9.5ish size twin would. What about single disc options?
I was looking at a mcleod street extreme ceramic disc, anyone ever run this clutch?
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: What clutch for t56 with higher hp in quicktime bell?
[Re: Silver70]
#2452776
02/16/18 08:59 PM
02/16/18 08:59 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Which Quicktime bellhousing are you using? There are a few diffrent part numbers that fit Gen3 Hemi to T56. RM-8074 fits small block to T56 Magnum and is behind my Gen 3. Height = 6.465 RM-6076 small mopar to LS1 T56 height = 5.93" RM-8077 Gen3 to Viper T56 height = 6.465" RM-8081 Gen3 to Hydraulic T56 height = 7.339 RM-8078 Gen3 to Mechanical T56 height = 5.525 You may need to get a different bell?
[Re: Silver70]
#2452830
02/16/18 11:09 PM
02/16/18 11:09 PM
Silver70
Rust Belt, SW PA
I have the 8077, it's rh starter location, but my headers will be facing forward, so no issue there. Found this pic: http://www.speedysgarage.net/challengerw...date_02_web.jpgI think that's why I read previously a twin disc wouldn't work... cause the post was about using a twin built for a challenger thats on the left of the pic and they use a different style flywheel. I was thinking a 6913-07 mcleod would work and from that pic, it sure looks like it'd fit.
[Re: Silver70]
#2453031
02/17/18 01:40 PM
02/17/18 01:40 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
The 6913-07 is what I use with an 8074 bell. The bell you have may need the thicker new Challenger style flywheel because of the depth.
Mopar to the bone!!!
[Re: RylisPro]
#2457109
02/25/18 01:51 AM
02/25/18 01:51 AM
Posts: 2,432 NorCal
RylisPro
NorCal
I was doing research and found that RM-8081 fits Gen3 Hemi to hydraulic T56. height = 7.339 RM-8078 fits Gen3 to Mechanical T56 height = 5.525 These bells are deesigned for late model Challengers and have the starter on opposite side of earlier small block Mopars I wrote the wrong spec on my post above and updated it
