What clutch for t56 with higher hp in quicktime bell? #2452600
02/16/18 03:37 PM
02/16/18 03:37 PM
Rust Belt, SW PA
Silver70 Offline OP
Silver70  Offline OP
Rust Belt, SW PA
What clutch are people running with t56s behind higher hp gen 3 hemis using quicktime bells?
I know they require a 130t flywheel and recommend a 10.5 gm clutch, but what about people running engines like a hellcat with 700+ hp? My understanding from my research is a twin disc will not fit... but I would think a smaller 9.5ish size twin would. What about single disc options?
I was looking at a mcleod street extreme ceramic disc, anyone ever run this clutch?
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: What clutch for t56 with higher hp in quicktime bell? [Re: Silver70] #2452612
02/16/18 04:00 PM
02/16/18 04:00 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I don't make Hellcat power so no actual feedback from me. Looking at a hellcat forum I found the BadBoyzz twin or triple disc setup.
http://bbgspeed.com/type/bbghcclutchkits/
Maybe worth looking into
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: What clutch for t56 with higher hp in quicktime bell? [Re: Silver70] #2452753
02/16/18 08:13 PM
02/16/18 08:13 PM
Rust Belt, SW PA
Silver70 Offline OP
Silver70  Offline OP
Rust Belt, SW PA
Those definitely won't fit a quicktime. I looked around and found blowproof bells for hellcats and they are much bigger than the ones quicktime sells.
Guess if you have to cut the floor, wouldn't matter to cut the firewall too. But someone out there has to know of a proven smaller clutch that would work by now.
Re: What clutch for t56 with higher hp in quicktime bell? [Re: Silver70] #2452776
02/16/18 08:59 PM
02/16/18 08:59 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Which Quicktime bellhousing are you using? There are a few diffrent part numbers that fit Gen3 Hemi to T56.
RM-8074 fits small block to T56 Magnum and is behind my Gen 3. Height = 6.465
RM-6076 small mopar to LS1 T56 height = 5.93"
RM-8077 Gen3 to Viper T56 height = 6.465"
RM-8081 Gen3 to Hydraulic T56 height = 7.339
RM-8078 Gen3 to Mechanical T56
height = 5.525
You may need to get a different bell?
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: What clutch for t56 with higher hp in quicktime bell? [Re: Silver70] #2452830
02/16/18 11:09 PM
02/16/18 11:09 PM
Rust Belt, SW PA
Silver70 Offline OP
Silver70  Offline OP
Rust Belt, SW PA
I have the 8077, it's rh starter location, but my headers will be facing forward, so no issue there.
Found this pic:
http://www.speedysgarage.net/challengerw...date_02_web.jpg
I think that's why I read previously a twin disc wouldn't work... cause the post was about using a twin built for a challenger thats on the left of the pic and they use a different style flywheel. I was thinking a 6913-07 mcleod would work and from that pic, it sure looks like it'd fit.
Re: What clutch for t56 with higher hp in quicktime bell? [Re: Silver70] #2453031
02/17/18 01:40 PM
02/17/18 01:40 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
The 6913-07 is what I use with an 8074 bell. The bell you have may need the thicker new Challenger style flywheel because of the depth.
Mopar to the bone!!!
Re: What clutch for t56 with higher hp in quicktime bell? [Re: Silver70] #2453081
02/17/18 03:47 PM
02/17/18 03:47 PM
Rust Belt, SW PA
Silver70 Offline OP
Silver70  Offline OP
Rust Belt, SW PA
Big thing was knowing if that clutch will fit helps me a lot. I read about the challenger specific clutch being too tall and would need an additional spacer cause of the splined part of the input shaft would bottom out on the disc.
Re: What clutch for t56 with higher hp in quicktime bell? [Re: Silver70] #2453821
02/19/18 10:53 AM
02/19/18 10:53 AM
Bowling Green, KY
BlakDak71 Offline
BlakDak71  Offline
Bowling Green, KY
I'll be running a McLeod RXT Twin Disc Part number 6923-07. This is good for 1000hp and bolts onto a 130t flywheel, fits inside a the QuickTime RM8074 and 8077.
I had good luck with the a lower cost McLeod behind my 392 as well, but a twin disc is definitely needed for the power level I'll be at now.
Re: What clutch for t56 with higher hp in quicktime bell? [Re: Silver70] #2454150
02/19/18 09:35 PM
02/19/18 09:35 PM
Rust Belt, SW PA
Silver70 Offline OP
Silver70  Offline OP
Rust Belt, SW PA
I may go with the rtx also.
Re: What clutch for t56 with higher hp in quicktime bell? [Re: RylisPro] #2457109
02/25/18 01:51 AM
02/25/18 01:51 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I was doing research and found that
RM-8081 fits Gen3 Hemi to hydraulic T56. height = 7.339
RM-8078 fits Gen3 to Mechanical T56
height = 5.525
These bells are deesigned for late model Challengers and have the starter on opposite side of earlier small block Mopars
I wrote the wrong spec on my post above and updated it
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: What clutch for t56 with higher hp in quicktime bell? [Re: Silver70] #2457131
02/25/18 02:45 AM
02/25/18 02:45 AM
Rust Belt, SW PA
Silver70 Offline OP
Silver70  Offline OP
Rust Belt, SW PA
I see those are the numbers shown on the holley website. Which I assume would be the correct ones. I looked at jegs before and they had different numbers.
I believe you typed the 8087 wrong and it should be rm-8078. 8078 says for gen 3 hemi to ford t56.
Re: What clutch for t56 with higher hp in quicktime bell? [Re: Silver70] #2457135
02/25/18 03:09 AM
02/25/18 03:09 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Whoops my bad haha! Typo switching back and forth on the webpages
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
