Disable 2006 300C TPS chime? #2455960
02/23/18 01:54 AM
02/23/18 01:54 AM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
I have a 2006 300C and all the tire pressure sensors are dead. I'm perfectly capable of monitoring my own tire pressure but I'm really tired of the dang chime going off every 5 minutes. Anyone knows a way to disable the chime?
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Disable 2006 300C TPS chime? [Re: MadMatt] #2456059
02/23/18 12:11 PM
02/23/18 12:11 PM
ky.
K
kenworth_goose Offline
K
ky.
Got a snap on scanner? If you have access you can try to get into the BCM and see if there is any place to turn it off. Other than that I'd jut put 4 new sensors in it and be done with it. If you decide to put new sensors in it only use Mopar sensors. We've had nothing but trouble trying to use any of the aftermarket ones.
Re: Disable 2006 300C TPS chime? [Re: MadMatt] #2456153
02/23/18 02:39 PM
02/23/18 02:39 PM
So Near, Yet So Far
topside Offline
topside  Offline
So Near, Yet So Far
Find the chime, replace it with something that vibrates, put that under your seat. Or better yet the passenger seat...
Hope all is good!
Re: Disable 2006 300C TPS chime? [Re: MadMatt] #2456257
02/23/18 06:00 PM
02/23/18 06:00 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yankee ingenuity:
https://www.youtube.com/watch?v=XRMoaVh8qsc
Or
http://www.tpmsbypass.com
Be aware, the 2006 works on a frequency of 315 MHz, the 2008 and later changed to 433 MHz.
Re: Disable 2006 300C TPS chime? [Re: MadMatt] #2456291
02/23/18 07:35 PM
02/23/18 07:35 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Ok great for that fix, what about a fix for all the chimes in my 2006 pickup plus the stupid backup warning when the door is open, a pain when backing to hook up the trailer.
Re: Disable 2006 300C TPS chime? [Re: John_Kunkel] #2456345
02/23/18 10:09 PM
02/23/18 10:09 PM
BDW Offline
BDW  Offline
Originally Posted By John_Kunkel
Yankee ingenuity:
Or
Nice, how long do the batteries last in these sensors?
Re: Disable 2006 300C TPS chime? [Re: BDW] #2456785
02/24/18 05:24 PM
02/24/18 05:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
My 2008 just tripped the light. My 2009 never did.
