Re: Cylinder head guys, stripped spark plug
[Re: dvw]
#2456608
02/24/18 12:27 PM
02/24/18 12:27 PM
Posts: 1,834 NW Indiana
fbs63
NW Indiana
I have used Helicoils with success on engines with that compression. It's best to have the head off so you can drill the correct angle and make sure the Helicoil does not hang out in the chamber.
[Re: dvw]
#2456618
02/24/18 12:57 PM
02/24/18 12:57 PM
Posts: 15 Delaware,USA
1jeff
Delaware,USA
http://www.timesert.com/They make some really nice stuff. I would pull the head, but I have greased the tap and repaired without when the customer didn't want to pay to pull it.
[Re: dvw]
#2456643
02/24/18 01:43 PM
02/24/18 01:43 PM
Posts: 2,102 Byron, NY
W.I.N. Racing
Byron, NY
I suggest you call one of the Head manufactures (Veney, Stage V, Indy, etc...) Veney dose/will not use stainless Helicoils for example...based on the SS heat transfer properties, and conductivity Somewhere you can get Copper inserts that will do the trick, but cant seem to find or remember where???
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: 1jeff]
#2456646
02/24/18 01:53 PM
02/24/18 01:53 PM
Posts: 10,551 Rittman Ohio
fourgearsavoy
Rittman Ohio
http://www.timesert.com/They make some really nice stuff. I would pull the head, but I have greased the tap and repaired without when the customer didn't want to pay to pull it. I have used Timeserts for years and they are pretty much become part of whatever you install them in. They will be better than the old threads once you install them perfectly. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: B G Racing]
#2456761
02/24/18 04:59 PM
02/24/18 04:59 PM
dartman366
Mt. Vernon, Ohio
It's February... head comes off easy... Welded or insert, you know the right answer on if you should fix it on the car.
If it were August and we were at Norwalk, we'd be having a different conversation. Exactly,with the money invested in that engine nows the time ,fix it correctly.What ever method you can see that it is done right and no issues will be found later.Now is not the time to temporary patch it. I agree 100% with both of these post replys you have too nice of a car and combo to not do it right and have the possibility of another failure at the wrong time.
[Re: dvw]
#2456810
02/24/18 05:53 PM
02/24/18 05:53 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Doug I use inserts all the time. No big deal. I have the tools to do it in the car. May just need to remove header.
JAKES AUTOMOTIVE
[Re: dvw]
#2456981
02/24/18 10:39 PM
02/24/18 10:39 PM
1jeff
Delaware,USA
Pulling the head isn't a big deal. More looking if the thread repair insert is OK. Obviously they work and are plenty strong. Just seeing if there are any other reasons not to use them. Doug Time sert makes thread repair kits for oe manufacturers. If you have any concerns, make a phone call. They know what they are doing.
[Re: dvw]
#2457030
02/24/18 11:37 PM
02/24/18 11:37 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
Maybe intake off, intake valve open and vacuum cleaner on that port while its done ?
1963 Plymouth Max Wedge 1971 Barracuda
[Re: SportF]
#2457248
02/25/18 12:43 PM
02/25/18 12:43 PM
fourgearsavoy
Rittman Ohio
While I'm not sure about the heat transfer question a Timesert is better in every way than a helicoil. To me a Timesert is a permanent repair and a Helicoil is just something to get you by. Now if I were doing one I would get the set of eight and do both heads while the chips are flying I just wish they were installed from the factory they are that good. Gus
