#2425057 - 12/28/17 06:04 PM B-Body Stock steering coupler questions
OLD318 Offline
The stock b body power steering couple allows for some fore-and-aft (in and out) play when the car goes over bumps etc...
If I'm reading this right, the Borgeson website lists a u-joint coupler to use when replacing the stock power steering gearbox with a borgeson box.
Does the u-joint replace the stock coupler?
How does the u-joint coupler allow for fore-and-aft play
I can see how it works when the shaft angle is not straight
in alignment with the steering gear. Does it also allow for
fore-and-aft???
Steering gear gurus's please chime in!!
Thanks for the ad
#2425124 - 12/28/17 08:08 PM Re: B-Body Stock steering coupler questions [Re: OLD318]
Ply72rr Offline
Loc: DE
I would use this instead of the Borgeson U-joint.
http://bergmanautocraft.com/proddetail.php?prod=5-0010
#2425199 - 12/28/17 10:16 PM Re: B-Body Stock steering coupler questions [Re: OLD318]
dangina Offline
Loc: Lethbridge, AB, Canada
I would also buy this as I hate the stock metal clip
http://bergmanautocraft.com/proddetail.php?prod=5-0009
#2456431 - 02/23/18 09:31 PM Re: B-Body Stock steering coupler questions [Re: dangina]
OLD318 Offline
bump...does anyone have any experience using the borgeson u-joint in lieu of the bergman steering coupler?
#2478483 - 04/06/18 06:21 PM Re: B-Body Stock steering coupler questions [Re: OLD318]
OLD318 Offline
I posted this question on the Borgeson website under mopar products... as you might have guessed I got the same nothing for an answer that I got here.... oh well.... thanks for the ad
#2479197 - 04/07/18 11:24 PM Re: B-Body Stock steering coupler questions [Re: OLD318]
Rick_Ehrenberg Offline
Loc: Marlboro, NY, USA
It will trash either the breakaway pin in the column (67-up) or the upper bearing at the top of the column as the car flexes. Which it WILL.
The pot coupling was there for a reason. Lose it at your peril.
Rick
#2480201 - 04/09/18 08:11 PM Re: B-Body Stock steering coupler questions [Re: OLD318]
MoJoe Offline
Loc: nj
dangina have you used this coupling? Is the spring clip needed with this set up as well?
#2481173 - 04/11/18 02:56 PM Re: B-Body Stock steering coupler questions [Re: Rick_Ehrenberg]
OLD318 Offline
Rick,
I didn't say I was going to use the Borgeson u-joint, I was asking if it is acceptable to use it given the stock steering couplers design which allows for "in/out" play.
Why does Borgeson advertise and sell this on their website as a mopar "solution" if it doesn't work?
Also, for example How is a 2003 Ford F-150 able to use a u-joint
and not a pot coupler?
#2481257 - 04/11/18 06:41 PM Re: B-Body Stock steering coupler questions [Re: OLD318]
GoodysGotaCuda Online   penguin-006
5.7L Hemi, 6spd
Loc: Texas
Typically newer cars have a slip yoke style steering column. My experience has been that it is primarily that way so that it can be assembled easier in the plant.
That said, I have a borgeson ujoint.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - Build page -> https://www.facebook.com/GoodysGotaHemi<-
1976 Dodge Warlock - "Her Truck" - 360/727 2wd
1969 Dodge Dart Custom Sedan - Grandma Edition - 318/904
2016 Subaru WRX - E30 Tune ~320whp
#2481808 - 04/12/18 06:08 PM Re: B-Body Stock steering coupler questions [Re: GoodysGotaCuda]
OLD318 Offline
What are you running it on? A-body, B-Body, E-body...?
have you had any issues going over speed bumps etc?
25,485 Registered Members
192,884 Topics
a friend sent me this
by azmopar
09/18/18 08:58 AM
Mopar parts swap at my building in Rockford, IL October 14
by Rhinodart
09/18/18 08:17 AM
CVF Releases New Pulley Finishes To Match Your Style
by Rustymuscle
09/18/18 08:04 AM
Tire Shake
by bigdad
09/18/18 08:03 AM
