Mds delete question #2456022
02/23/18 10:10 AM
02/23/18 10:10 AM
MI
68shifter Offline OP
MI
Just curious if anyone has just used soft plugs in place of buying the mds delete plugs? Not that the plugs are expensive but just curious if there's any reason you couldn't do it? Thanks.
Re: Mds delete question [Re: 68shifter] #2456113
02/23/18 01:50 PM
02/23/18 01:50 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
I have a couple blocks here but none are MDS.Since the solenoids or plugs are in the oil galley an oil pressure drop could happen if neither are used to direct the flow.
Re: Mds delete question [Re: 68shifter] #2456330
02/23/18 09:08 PM
02/23/18 09:08 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
a soft plug will not work, the oil will squirt out the bypass hole and flood the rocker area, may even drain the pan as well as a drop in oil pressure.
Re: Mds delete question [Re: 68shifter] #2456927
02/24/18 08:48 PM
02/24/18 08:48 PM
Otsego, mi. by Martin 131 stri...
JT612GTX Offline
JT612GTX  Offline
Use the mds delete plugs, they work fine,
put them on a rebuilt 5.7 long block for my 05 Ram,
prime the engine before starting, check oil pressure!
86 Daytona - 612/ glide - 2400lbs - 8.60 alot more left
71 S/G Challenger - 469/glide - 2800lbs - 9.20s and tuning
70 Challenger - mild 440/727 - 3475lbs - 10.96 best
70 GTX - future quick 16? more $$$$$$
Re: Mds delete question [Re: 68shifter] #2456963
02/24/18 10:14 PM
02/24/18 10:14 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
If you use just the MDS delete plugs without replacing the MDS lifters your engine will only run on 4 cylinders.
Re: Mds delete question [Re: HotRodDave] #2457126
02/25/18 02:35 AM
02/25/18 02:35 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
this is true fan
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Mds delete question [Re: 68shifter] #2457185
02/25/18 08:25 AM
02/25/18 08:25 AM
MI
MI
It's getting delete lifters. Just curious on the soft plugs. Ordered the delete plugs.
I think you could actually do two soft plugs, essentially one each where the orings are on the delete plugs but I'm not messing with it over 50 bucks.
Re: Mds delete question [Re: HotRodDave] #2457196
02/25/18 10:30 AM
02/25/18 10:30 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
+10000000000000000000000000000000000000
it will not work it bleeds off pressure , I pulled a wrecked Molnar crank and some burned up Oliver rods from a short block that someone (not me) tried it on.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Mds delete question [Re: 68shifter] #2458053
02/26/18 08:23 PM
02/26/18 08:23 PM
JT612GTX Offline
JT612GTX  Offline
I failed to mention my trucks not wired for mds, the engine was built using
regular lifters, the reman block just had the holes for mds, so yes your right,need the right ones, I just had to plug the holes.
