Slant 6 Torsion Bars 622 / 623 Install Sides #2456018
02/23/18 09:33 AM
02/23/18 09:33 AM
Gravataí, RS, Brazil
360tripleblack77 Offline OP
Hi folks, yesterday I received my slant 6 622 / 623 torsion bars but I've some doubts about sides of installation. Which one is Driver and Passenger side.
'77 Brazilian Dodge Charger R/T - Street Car
Footbrake, Pump Gas, SB Mopar 360" N/A
3300lbs, Leaf Spring + Assassin Bars
Best 1/8 mile ET
1.50 60' / 4.31 330' / 6.73@102.54mph
Re: Slant 6 Torsion Bars 622 / 623 Install Sides [Re: 360tripleblack77] #2456020
02/23/18 09:48 AM
02/23/18 09:48 AM
Guitar Jones Offline
With Mopar part numbers the right is the even last number and left is the odd number. There are a few exceptions though so I don't know about those bars specifically.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Slant 6 Torsion Bars 622 / 623 Install Sides [Re: Guitar Jones] #2456031
02/23/18 10:41 AM
02/23/18 10:41 AM
Thanks GJ.
I found this information in another forum:
There are numbers stamped into the end of the torsion bar which will identify what diameter bar it is, but you to have the bar removed to see it. There's usually some paint splotch too...different diameters have different colours.
A-body Slant 6
.83" - yellow - 622/623(R/L early) 880/889(late)
A-body 2-bbl V8
.85" - Olive - 624/625(R/L early) 890/891 late)
A-body 4-bbl V8
.87" - Blue - 626/627(R/L early) 892/893(late)
My bars has the yellow color spots also...
Best 1/8 mile ET
Re: Slant 6 Torsion Bars 622 / 623 Install Sides [Re: 360tripleblack77] #2456112
02/23/18 01:48 PM
02/23/18 01:48 PM
AndyF Offline
AndyF  Offline
Even part numbers on right side of car (passenger side). Paint splotches to the rear of the car if you care about that. LH bar should have two splotches, RH bar has one splotch.
Re: Slant 6 Torsion Bars 622 / 623 Install Sides [Re: AndyF] #2456180
02/23/18 03:19 PM
02/23/18 03:19 PM
Thank you Andy! I really appreciate your help. up
Best 1/8 mile ET
