Oil priming a 440
#2455996
02/23/18 04:35 AM
02/23/18 04:35 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
HI,
Where do I position the camshaft when manually priming the oil on a freshened 440 ?
THANKS
1963 Plymouth Max Wedge 1971 Barracuda
Re: Oil priming a 440
[Re: ozymaxwedge]
#2456003
02/23/18 04:57 AM
02/23/18 04:57 AM
ozymaxwedge
Australia
Yeah Dave onto the reverse thing but there is one spot where the oil holes line up on the cam
[Re: ozymaxwedge]
#2456117
02/23/18 02:03 PM
02/23/18 02:03 PM
RapidRobert
As you know you want to do as minimal turning as you can. If you are still on dot to dot (6/12 0'clock) which is #6 TDC firing, preoil now to do one bank (I forget which) then back up CCW the dampener 3/4 turn (to #8 TDC firing) & preoil the other bank. As you noted it is the cam position as opposed to strickly the crank position that lines up its cam journal holes to oil the heads so an adv/ret on the cam phasing will change this slightly but get to those 2 points & adj slightly on either side as/if needed till it flows. cut a strip of paper 17.082" to use as a ruler around the dampener to easily go from #6 back to #8.
[Re: ozymaxwedge]
#2456388
02/23/18 11:33 PM
02/23/18 11:33 PM
ozymaxwedge
Australia
Ahhhh sorry guys I forgot to say it has indy heads with the rear oil line feed
[Re: ozymaxwedge]
#2456421
02/24/18 12:15 AM
02/24/18 12:15 AM
ozymaxwedge
Australia
Yes but that is straight off the rear cam bearing that has one hole
[Re: ozymaxwedge]
#2456432
02/24/18 12:31 AM
02/24/18 12:31 AM
ozymaxwedge
Australia
OK so should not matter where the cam is ?
[Re: ozymaxwedge]
#2456457
02/24/18 01:15 AM
02/24/18 01:15 AM
ozymaxwedge
Australia
OK thanks. With the oil line restrictors I will check it out , I notice that some guys run both lines from one outlet a and the other is a pressure, we have always run one from each. This has got change oil volume yeah ?
[Re: ozymaxwedge]
#2456462
02/24/18 01:24 AM
02/24/18 01:24 AM
Posts: 2,363 Cotati, CA
Dave Hall
Cotati, CA
OK thanks. With the oil line restrictors I will check it out , I notice that some guys run both lines from one outlet a and the other is a pressure, we have always run one from each. This has got change oil volume yeah ? It doesn't matter if you run the lines from a tee or one to each hole. Those two 1/8" NPT ports are tapped to the main gallery. I run a tee because my oil pressure gauge comes off of one. Did you have a problem? Isn't it the middle of your race season right now?
[Re: Cab_Burge]
#2456665
02/24/18 02:22 PM
02/24/18 02:22 PM
RapidRobert
After giveing it some thought, Transman is right, 2 full turns ain't gonna come close to wiping enough lube off of the lobes to cause a problem. As said with you haveing the head valvetrain(s) being oiled full time from the oil sender port at the top rear of the block you can preoil at any crank/cam clocking. that's even better yet as nothing needs to be moved at all & you can set the dist for fireup. Good luck on fireup.
[Re: ozymaxwedge]
#2459245
03/01/18 03:44 AM
03/01/18 03:44 AM
ozymaxwedge
Australia
Primed good, 85+psi straight away and all rockers flowed oil .
Cheers
