RKE Camshaft info?
#2455829
02/22/18 09:29 PM
02/22/18 09:29 PM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
I ended up with a new big block camshaft still in the original box, marked RKE Camshafts.
Numbers on the label are 91055 and 111801. No cam spec sheet in the box.
It came from a long time drag racer but he couldn't remember any specifics either, other than saying he wouldn't have saved it unless it was some form of a high performance cam. My memory is such anymore that I sure can't criticize him for that.
Most searching I've done comes up blank. What little I have found makes me think they were an aftermarket parts manufacturer of some sort. They did do a trademark registration at some point but it doesn't appear that was maintained.
Did find one mention in an AMC forum, but that was a dead end too.
Anyone here know anything about them by chance? Thanks in advance.
Lead, follow or get the hell out of the way
Re: RKE Camshaft info?
[Re: Sport440]
#2457190
02/25/18 09:56 AM
02/25/18 09:56 AM
peabodyracing
Minnesota
Thanks much for the info. I've tried again and am not coming up with a website. I've tried Bing and Google both, but will admit searching is not my forte.
Dimensionally it sure appears it's a big block cam.
[Re: peabodyracing]
#2458055
02/26/18 08:27 PM
02/26/18 08:27 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
I used google, tried it again today and it wouldn't come up. But went back to Saturday when I found it; it likes the words {rke camshafts} but without the parenths. rke camshafts or maybe this will work for you. https://www.trademark.com IMO, it would be easier to get some calipers out and just measure it. That way you would know the approximate lift, that would give you a clue to its duration. example, .480 lift probably around 238/241 @ .050 Edit, the http didn't work for me. just try rke camshafts in lower caps. If you use rke cams, rke mopar cams, doesn't work on google.
[Re: Sport440]
#2458279
02/27/18 10:51 AM
02/27/18 10:51 AM
peabodyracing
Minnesota
I did as you recommended and come up with about 478 lift.
I appreciate your help! I'm dangerous now.
[Re: Cab_Burge]
#2458436
02/27/18 03:43 PM
02/27/18 03:43 PM
peabodyracing
Minnesota
I should have been clearer in my last post. I measured lobe height compared to the base diameter and multiplied the difference by 1.5.
Assuming this is correct, I don't know that it's anything that special.
[Re: peabodyracing]
#2458514
02/27/18 06:26 PM
02/27/18 06:26 PM
Sport440
Canton, Ohio
Assuming this is correct, I don't know that it's anything that special. Yep, you did that right, average .480 lift cam. Back in the day, All those mild .480 lift cams were called, 3/4 cams. Yep, Ive got a 4 barrel, headers and a 3/4 cam, oh yeah shes a racer.
[Re: Sport440]
#2458576
02/27/18 09:22 PM
02/27/18 09:22 PM
peabodyracing
Minnesota
Thanks again for your guidance!
You were laughing about the 3/4 race cam terminology; years ago I was in a local speed shop and a guy walked in wanting a cam, but didn't want something as radical as a 3/4.
Asked if they had a 5/8th. The counter guy managed to keep a straight face and handled it well. We were all idiots to some extent. I remain so to this day it seems.
[Re: peabodyracing]
#2458590
02/27/18 09:57 PM
02/27/18 09:57 PM
Posts: 20,157 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Asked if they had a 5/8th. The counter guy managed to keep a straight face and handled it well. We were all idiots to some extent. I remain so to this day it seems. I don’t know if you are on Facebook or not but some of the mopar groups make my life worth living. I don’t even watch comedians anymore as I get my daily laughs and without I don’t think I could make it through our PA Winters. Lol. Most of the guys will go out of their way trying to help guys but you soon learn some can’t be helped.
