Re: How to support car with K frame/suspension removed
[Re: kbcuda]
#2455612
02/22/18 02:30 PM
02/22/18 02:30 PM
RapidRobert
if you located 4 wheels like those (shouldn't be too hard) maybe a welding shop could fab up some brackets for cheap.
[Re: kbcuda]
#2455722
02/22/18 05:47 PM
02/22/18 05:47 PM
Posts: 1,126 Home of the Bluegrass
MoparJunkie
How soon are you needing to borrow them? I have a set front/back but they are on the Superbee currently.... When it's done I'd be more than happy to let you borrow them. They are the US car tool set.
"It takes a Mopar to catch a Mopar” 1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54 2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
[Re: njmopar]
#2455736
02/22/18 06:25 PM
02/22/18 06:25 PM
DaytonaTurbo
Manitoba, Canada
I would recommend pneumatic tires as it will allow you to roll over cracks or bumps much easier. Mine are about 10" in diameter For example the ramp up into the trailer, a solid wheel would have been really difficult to use. The guy that did my convertible top had a gravel drive, which also would have been impossible to move solid wheels on.
I used the casters like in the pic, the casters with the phenolic tires and they are actually pretty good. I've moved mine around on concrete, gravel, trailers, etc. There's not much weight once the front clip is off. I can lift the front of the car up in the air by hand.
[Re: MoparJunkie]
#2455764
02/22/18 07:12 PM
02/22/18 07:12 PM
Posts: 1,945 roanoke va
kbcuda
roanoke va
How soon are you needing to borrow them? I have a set front/back but they are on the Superbee currently.... When it's done I'd be more than happy to let you borrow them. They are the US car tool set. Probably before next weekend....only would need the fronts..could someone provide the general size dimensions of the angle piece and the length of the vertical tube? I can drill the holes myself..
