C body rear disc brake conversion #2455158
02/21/18 04:51 PM
02/21/18 04:51 PM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
Who makes the best rear kit to road race a big butt C body 74 cop Fury?? May upgrade the stock factory fronts as well. Would like some made in USA stuff. Thanks
CALMED THE QUAKE!!!(AGAIN!)
Re: C body rear disc brake conversion [Re: Spyphish] #2455184
02/21/18 05:50 PM
02/21/18 05:50 PM
Andrewh Offline
Andrewh  Offline
fortunatly that isn't c body specific.
any 8 3/4 kit will work.
I have a tsm kit sitting on a shelf from way back.
I would check dr diff's offerings to see what the best choices are out there.
AndyF had some one off stuff using viper brakes on a c-body at one point.
But I think that was for the 73 and back stuff for the fronts anyway.
your problem with those are needing 18 inch rims.
c-body stuff is the biggest you can get and still fit in 15's.
Re: C body rear disc brake conversion [Re: Andrewh] #2455217
02/21/18 06:58 PM
02/21/18 06:58 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: C body rear disc brake conversion [Re: hemi71x] #2455233
02/21/18 07:40 PM
02/21/18 07:40 PM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
Could you call me at 337-499-44 three five, I could not get the number to work. Thanks
Re: C body rear disc brake conversion [Re: Spyphish] #2455238
02/21/18 07:54 PM
02/21/18 07:54 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
that imperial stuff is 5 on 5 i believe....
Re: C body rear disc brake conversion [Re: savoy64] #2455240
02/21/18 07:57 PM
02/21/18 07:57 PM
hemi71x Offline
hemi71x  Offline
NO, it's not. Regular 4 1/2
1960's Imperials were 5"
That's what your most likely thinking of.
Re: C body rear disc brake conversion [Re: Spyphish] #2455255
02/21/18 08:19 PM
02/21/18 08:19 PM
AndyF Offline
AndyF  Offline
Rear is easy, just call Cass at DoctorDiff and order it up.
Front is a little more of a challenge if you want something bigger than factory. I used to build a 13 inch Viper kit for the C body cars but I discontinued it years ago. Sold almost zero of them so decided there wasn't any point in making parts for C body guys. Here is what the kit looked like back in the day.
Re: C body rear disc brake conversion [Re: hemi71x] #2455798
02/22/18 08:46 PM
02/22/18 08:46 PM
Houston
I
it's Bob Offline
it's Bob  Offline
I
Houston
Imperial hub patterns
beginning of time to 1966 5 x 5.5 inches
1967-1973 5 x 5 inches
1974-75 5 x 4.5 inches
Re: C body rear disc brake conversion [Re: it's Bob] #2455822
02/22/18 09:18 PM
02/22/18 09:18 PM
hemi71x Offline
hemi71x  Offline
Thank's Bob, for the bolt pattern information. up
I never knew all the sizes, throughout the years.
Re: C body rear disc brake conversion [Re: Spyphish] #2456308
02/23/18 08:07 PM
02/23/18 08:07 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Yup, contact Dr. Diff . . . Cass probably has the stuff in stock and ships promptly if he does . . .
Re: C body rear disc brake conversion [Re: it's Bob] #2456521
02/24/18 04:07 AM
02/24/18 04:07 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Is this true for 300's as well?
Re: C body rear disc brake conversion [Re: Dave Hall] #2456867
02/24/18 07:07 PM
02/24/18 07:07 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
No. Imperial didn't it's own thing for a long time.
As for the 75 Imperial rear disc brakes, I'd run and hide before I put them on a car. You can forget about ever getting replacement or repair parts.
- Stu Harmon
Re: C body rear disc brake conversion [Re: feets] #2456888
02/24/18 07:36 PM
02/24/18 07:36 PM
hemi71x Offline
hemi71x  Offline
Too many people just don't know much about those rear disc brakes, in this day and age.
Yes, the rotors would be difficult to obtain, but if the are in good condition, then there is no need to replace them.
The calipers that are used, are nothing more than 73-76 A body calipers, which there are a bazillion of them out there.
And the pads are the same, and all that you have to do is take a grinder to the portion of the metal "lip" at the edge, and grind it away.
Easy, peasy.
And if the lining on the parking brake shoes ever wore down, just get them relined at a shop that is capable of doing something like that.
Then everything else in those brake systems never need replacement.
Re: C body rear disc brake conversion [Re: Spyphish] #2456945
02/24/18 09:32 PM
02/24/18 09:32 PM
Colorado
Bob J Offline
Bob J  Offline
Colorado
Well I have a set of the 74 Imp. rear disc int the barn somewhere. I should look as I have no idea what shape that they are in as they have been in the parts shelf for at least 20 years. They may work OK on the 57 DeSoto. I would think that if I have to replace the rotors that a Wilwood setup would be cheaper. I didn't find rotors on a quick look.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS
68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam
65 Chrysler 300 Convert. project
57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son
2003 Dodge Dakota R/T "DEAD"
Re: C body rear disc brake conversion [Re: Spyphish] #2458056
02/26/18 08:29 PM
02/26/18 08:29 PM
Houston
I
it's Bob Offline
it's Bob  Offline
I
Houston
The problem with the rear rotors is that the parking brake friction surface is inside the rotor hub. The disc caliper has no function with the P brake as most modern rear disc cars do. You cannot replace the rear rotor with a hat and disc combo and keep the P brake. To do that you would need a new caliper and now you need a new mount and now you have to completely redesign the whole mess. Or call Dr Diff/Cass and use one of his kits.
Oops, Bob J, I think I misinterpreted your post. I thought you were saying that you could use everything Chrysler and just replace the discs with something else.
Re: C body rear disc brake conversion [Re: Spyphish] #2458470
02/27/18 05:03 PM
02/27/18 05:03 PM
Canada
CrAzYMoPaRGuY Offline
Canada
C body front kits are now made by Wilwood. I made my own adapted C body Wilwoods years ago. Just bought the kit. lol
CrAzYMoPaRGuY
Re: C body rear disc brake conversion [Re: it's Bob] #2458573
02/27/18 09:21 PM
02/27/18 09:21 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
[quote=it's Bob]The problem with the rear rotors is that the parking brake friction surface is inside the rotor hub. The disc caliper has no function with the P brake as most modern rear disc cars do. You cannot replace the rear rotor with a hat and disc combo and keep the P brake. To do that you would need a new caliper and now you need a new mount and now you have to completely redesign the whole mess. Or call Dr Diff/Cass and use one of his kits.
You could always plumb in a hydraulic brake lock valve.
