Re: BB Autozone Duralast water pump OK?
[Re: Exit1965]
#2454513
02/20/18 01:05 PM
02/20/18 01:05 PM
RapidRobert
I've had outstanding luck with parts house water pumps no matter what the brand (& heard of very few comebacks). You'll be fine.
[Re: Exit1965]
#2454587
02/20/18 03:26 PM
02/20/18 03:26 PM
Posts: 637 SoMd, USA
135sohc
SoMd, USA
I had a almost brand new (1 month old)'good' brand water pump self destruct on my 4.7 truck 2 years ago destroyed the radiator, shroud, AC condenser fan shroud/assembly. Fan blade, clutch and the waterpump pulley went bouncing and skipping across the highway never to be found. Kind of amazing it did not sever the transmission cooler or PS lines on its way out. Left a nice gouge on the frame rail.
OEM replacement water pump (NOT the value line stuff) "made in china"
Toss up between AZ and Advance, the advance one said 'assembled in USA, parts from china, mexico, italy and USA.
The AZ one looked almost identical but was "made in china" like the OEM one.
with a coupon I went with the advance one, fingers crossed its been ok for the last two years. As always like most parts anymore from the store give it a once over before the money changes hands.
[Re: 135sohc]
#2454648
02/20/18 04:58 PM
02/20/18 04:58 PM
RapidRobert
As always like most parts anymore from the store give it a once over before the money changes hands. & I had no idea that it could have "made in USA" on the outside and maybe (likely) some of the innards are inferior stuff. what a mess!
[Re: Exit1965]
#2454763
02/20/18 09:25 PM
02/20/18 09:25 PM
Posts: 619 nj
JAMESDART
nj
