Re: who runs torque straps, limiters?
[Re: superchuck]
#2454599
02/20/18 03:41 PM
02/20/18 03:41 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
I've used torque straps forever to save the left motor mount when foot braking and on stick shift cars, even used chains with a turn buckle for a little while I used the power steering boss on the water pump to bolt to the 1/4x1 inch wide strap to the left front sub frames, my current street car, ex drag race car, has a piece of aluminum 1x1x.085 aluminum angle on it that worked well also
[Re: superchuck]
#2454641
02/20/18 04:40 PM
02/20/18 04:40 PM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
The torque strap that schumacher sells is a nice piece.
68 Barracuda Formula S 340 87 "Chrysler" Conquest
[Re: superchuck]
#2454655
02/20/18 05:05 PM
02/20/18 05:05 PM
Posts: 11,408 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
The old trick is to use a rubber mount on the left side and use what is essentially half of a motor plate and call it a strap.
[Re: Bad340fish]
#2454671
02/20/18 05:41 PM
02/20/18 05:41 PM
Posts: 13,319 Marion, South Carolina [><]
an8sec70cuda
[Re: an8sec70cuda]
#2454678
02/20/18 05:55 PM
02/20/18 05:55 PM
Posts: 4,651 Wichita
GY3
Wichita
I use the Schumacher piece as well.
Easy to install and very clean looking.
My Early B has a habit of tearing the drivers side in half!
[Re: srunge55]
#2454709
02/20/18 06:47 PM
02/20/18 06:47 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I have heard of some guys using a solid MM on the drivers side and a stock rubber on the passenger side. A big part of using a strap or motorplate is to remove the stress and shock from the left side of the block where the mount is bolted. This would make it worse.
[Re: superchuck]
#2454815
02/20/18 10:45 PM
02/20/18 10:45 PM
Posts: 361 Canada
onig
Canada
Just curious, but who has seen a block get damaged from a solid motor mount on the driver's side? Our SB has the solid mount pushing about 650HP and still going strong.
69 Dart
[Re: DaveRS23]
#2454857
02/20/18 11:47 PM
02/20/18 11:47 PM
Posts: 4,963 new jersey usa
11secdart
new jersey usa
I made my own with a piece of threaded rod and two heim ends with a piece of plastic tubing over the threaded rod. It goes from the bolt on the front of the head to the motor mount boss on the K frame. I was worried when i went from the W2 head engine to the 408 with Indy 360-1 heads that it would`t fit but it did in almost exactly the same place. Whats nice is that it is adjustable up or down if need be
[Re: GY3]
#2454874
02/21/18 12:31 AM
02/21/18 12:31 AM
Posts: 5,442 Indiana
YO7_A66
Indiana
I just installed a Schumaker strap a few weeks ago. No drive time yet but I too was wondering if there can be any damage from bolting these onto the motor mount bracket hole. I assume the motor mount helps to support the block when mounting the strap at this location.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: superchuck]
#2454878
02/21/18 12:51 AM
02/21/18 12:51 AM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Has anyone used the Shumacher Poly-Locs?
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: superchuck]
#2454916
02/21/18 02:02 AM
02/21/18 02:02 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I run a Moroso solid mount on the driver side, stock mount on the pass side. I’ve heard people say that this could be hard on the block, But I’ve never seen someone’s block fail at the motor mount. I don’t make a lot of power either, so I think I’m safe.
[Re: OhioMopar]
#2454946
02/21/18 04:01 AM
02/21/18 04:01 AM
Posts: 1,908 Nebraska
4406bbl
Nebraska
Yes the polylocs work good. The motor stays in place and does not shake like aftermarket junk. I have put them on several shaker hood cars to save the shaker, worth the money to stop damage. The strap is also nice, have one on my 340 4-speed, made shifting way better also.
