Removing Rusty Rods & Pins From Pistons...
#2454392
02/20/18 02:45 AM
02/20/18 02:45 AM
Posts: 4,204 Fort Worth, TX
Clair_Davis
Fort Worth, TX
So I picked up a 440 block and it came disassembled with some rods with pistons mounted. The pistons appear to be old Speed Pro / FM L2355's 0.040" over. The block is standard bore, so this is really just a box of parts. The pistons look like they've got next to zero time on them, guessing that a cam wiped or something else caused serious bearing wear, and the crank was pulled. The pistons/rods must have been stored somewhere that they either got wet, or just condensation over years got to them. The pins now don't move, so I'm wondering if there is any way to remove the pins without damaging the pistons any further. Ugly pics: 440_Piston-01 by clair_davis, on Flickr 440_Piston-02 by clair_davis, on Flickr 440_Piston-03 by clair_davis, on Flickr My initial thought is to hit the pins with some PB Blaster and see if they will loosen up. If they'll budge, heat the rod and press them out. Open to suggestions - this is mostly an operation to see if the pistons can be saved, but they're not parts I'll be using myself. Thanks, Clair
Re: Removing Rusty Rods & Pins From Pistons...
[Re: Clair_Davis]
#2454439
02/20/18 09:29 AM
02/20/18 09:29 AM
Posts: 1,486 STL
cdstl
STL
Trans fluid and acetone 50/50 is my go-to "Magic Juice". The acetone does evaporate.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
[Re: Clair_Davis]
#2461856
03/06/18 02:31 AM
03/06/18 02:31 AM
Clair_Davis
Fort Worth, TX
OK, small update... I haven't tried the Evaporust yet, but the two flavors of ATF and the PB Blaster have results. After a couple days soaking, I held the rod big ends in a vice and smacked the pistons with a plastic dead-blow hammer and they all started to move. I would say that the the ATF + mineral spirits moved the easiest, but none were going to move by hand after just a couple days. Also, as cdstl noted, the acetone does evaporate out pretty quickly. It doesn't mix like the mineral spirits do, so you need to stir it periodically and add more acetone from time to time - things I didn't do.
The PB Blaster was the slowest to loosen up, and had the most friction after the two-day soaking. However, after soaking all three for a few more days, all three loosened up enough to move by hand - after another round of dead-blow treatments. Pretty quickly, all three could be moved by hand, and the PB piston was actually the easiest to move, followed by the ATF+spirits, then the ATF+acetone.
So, given a week and some dead-blow persuasion, all three methods appear to work. I've got 5 more pistons to go, so I'll repeat these three again, and then do a pair with the Evaporust just to say I did. Maybe there will be a clear leader after that effort.
[Re: Clair_Davis]
#2461981
03/06/18 01:31 PM
03/06/18 01:31 PM
Posts: 2,487 God's Country Maryland
GODSCOUNTRY340
Here's what industry has used for decades.
[Re: GODSCOUNTRY340]
#2462167
03/06/18 08:02 PM
03/06/18 08:02 PM
dogdays
I didn't see anything in your picture that couldn't be rehabilitated and reused. As a matter of fact once you got the pistons free you could probably use the rod/piston combination without taking them apart. The rod bearings shielded the rod big ends.
Any machine shop worth their salt should be able to press out the pins without damaging the pistons. That's just basic engine shop work. Literally tens, maybe hundreds of millions of pistons have been pressed on and pressed off since the automobile age began.
R.
[Re: Clair_Davis]
#2462341
03/06/18 11:40 PM
03/06/18 11:40 PM
Clair_Davis
Fort Worth, TX
Ah, Kroil... I've heard of that stuff before but never used it. Do they only sell directly, or is it on the shelf somewhere? Google shows AutoZone, but I don't recall seeing it there. Maybe I'll try that stuff and the Evaporust if I can find them both locally.
It crosses my mind to just free up the pins in the pistons, and sell them as assemblies for someone else to mess with. At least one rod is toast from a pitting perspective, so it isn't a drop-in set, even with some additional cleanup.
[Re: Clair_Davis]
#2462658
03/07/18 04:40 PM
03/07/18 04:40 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
Very reasonable option. Apply money from sales to new parts that will have much better fatigue strength.
