instrument voltage limiter / regulator #2454332
02/20/18 01:02 AM
02/20/18 01:02 AM
Greenwood Lake, NY
fuelishnsilly Offline OP
Greenwood Lake, NY
I know there is a company out there who sells solid state voltage regulators / limiters for the instrument clusters. Is there any out there that is better than the others? If so, what is the name of the company. I don't want to fry my gauges again with this antiquated point style regulator. Vehicle is a 69 roadrunner.
inherited a 69 roadrunner from my grand pop.
Re: instrument voltage limiter / regulator [Re: fuelishnsilly] #2454356
02/20/18 01:44 AM
02/20/18 01:44 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Real Time Engineering,
Re: instrument voltage limiter / regulator [Re: fuelishnsilly] #2454856
02/20/18 11:46 PM
02/20/18 11:46 PM
Greenwood Lake, NY
Greenwood Lake, NY
Thanks. I thought the letters were RTE but I couldn't remember what it stood for.
Re: instrument voltage limiter / regulator [Re: fuelishnsilly] #2455361
02/21/18 11:46 PM
02/21/18 11:46 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
There is a solid state regulator available today that is a direct replacement for your mechanical regulator.
The modern one even looks identical.
Echlin VR-1001, or Standard (Blue Streak) VR-128
For your instrument cluster regulator.
http://1962to1965mopar.ornocar.org/ml-instrument-voltage-regulator64.html
Re: instrument voltage limiter / regulator [Re: fuelishnsilly] #2455384
02/22/18 12:35 AM
02/22/18 12:35 AM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
I’ve built a few from the Rich Ehrenberg article online. Only cost a few bucks, used old limiters so they just plug in. A quick and easy DIY project.
Re: instrument voltage limiter / regulator [Re: fuelishnsilly] #2456498
02/24/18 02:35 AM
02/24/18 02:35 AM
Greenwood Lake, NY
Greenwood Lake, NY
I got the new one from Real Time Engineering today. Hardest part about it was trying to squeeze my hand in between the metal bracket and the wire harness and then get all three prongs into the back of the circuit board with not really being able to see at the same time. lol.
Re: instrument voltage limiter / regulator [Re: fuelishnsilly] #2456683
02/24/18 02:51 PM
02/24/18 02:51 PM
BlueRacer69 Offline
BlueRacer69  Offline
Who won, you or the circuit board. Just joking. laugh
Re: instrument voltage limiter / regulator [Re: fuelishnsilly] #2456815
02/24/18 05:59 PM
02/24/18 05:59 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Using the RTE limiter, do you still use the original condenser that plugs into it?
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: instrument voltage limiter / regulator [Re: fuelishnsilly] #2457029
02/24/18 11:36 PM
02/24/18 11:36 PM
Greenwood Lake, NY
Greenwood Lake, NY
You can but its not required.
Re: instrument voltage limiter / regulator [Re: fuelishnsilly] #2457031
02/24/18 11:37 PM
02/24/18 11:37 PM
Greenwood Lake, NY
Greenwood Lake, NY
@Blueracer,
I guess I won since its in there and working now. Although there was some carnage. My hands have some battle scars lol.
