power disk brakes booster #2454131
02/19/18 09:03 PM
02/19/18 09:03 PM
mo71cuda Offline OP
mo71cuda  Offline OP
My brake pedal is hard, but no brakes. This is a power breaker booster failure? If so how to I test to confirm and who is the best to rebuild it?
The car is a 71 cuda 340
Re: power disk brakes booster [Re: mo71cuda] #2454135
02/19/18 09:10 PM
02/19/18 09:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Did this just happen to a working system or is it a new installation?
Re: power disk brakes booster [Re: John_Kunkel] #2454137
02/19/18 09:12 PM
02/19/18 09:12 PM
mo71cuda Offline OP
mo71cuda  Offline OP
Just happened, original system
Re: power disk brakes booster [Re: mo71cuda] #2454237
02/19/18 11:19 PM
02/19/18 11:19 PM
split the booster/MC & pull MC forward enough to eyeball the pushrod. eng idling. have a helper press the pedal. You under the hood see if the round nub threaded pushrod moves out/forward like it should. I'm thinking the booster (possibly the check valve).
Re: power disk brakes booster [Re: RapidRobert] #2454732
02/20/18 07:46 PM
02/20/18 07:46 PM
mo71cuda Offline OP
mo71cuda  Offline OP
Any additional input?
If the booster is bad who rebuilds them or sells replacements.
Re: power disk brakes booster [Re: mo71cuda] #2454782
02/20/18 09:53 PM
02/20/18 09:53 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Dewey Boosters - I think he is in Oregon.
However make sure you don't have a vacuum leak first.
Re: power disk brakes booster [Re: Morty426] #2455186
02/21/18 05:54 PM
02/21/18 05:54 PM
mo71cuda Offline OP
mo71cuda  Offline OP
Thanks for the info green
