Re: 71 340 e-body diff
[Re: BLACKHEMIRR]
#2454174
02/19/18 10:24 PM
02/19/18 10:24 PM
Posts: 29,650 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
That is the 1970 chart as mentioned above. It appears to have been stolen & modified though........ For the record, no one has permission to take images from HH, let alone modify them.
[Re: VCODE]
#2454204
02/19/18 10:54 PM
02/19/18 10:54 PM
Posts: 2,901 New Jersey Bada Bing
bremotorsports
Bob,
Broadcast Sheet Axle Code 015
ALLEGEDLY, Code 015, at least as far as info I have seen to this point, indicates that for 71 E-Body with 3.23 standard axle, with 11" rear brakes and 7260 u-joints (both of which I have) shows the spec requires the 1-7/8" 489 diff. Sorry to disappoint any previously published info!!! Also, the date codes on the gearset are dead on for my car, and the diff assembly date (2/9/71) AND the ratio (3.23) are STAMPED DIRECTLY INTO THE DIFF CASE. No tag under and mounting nut.
I will also state without question that my car was 100 % untouched prior to my acquisition, as verified by conversation with the original owner, as well as my observations during disassembly.
Bill Rolik
[Re: bremotorsports]
#2454283
02/20/18 12:00 AM
02/20/18 12:00 AM
Posts: 2,368 White Plains, NY
VCODE
White Plains, NY
Bob,
Bill Rolik
Thanks Bill, The info for my 014 is wrong in the white book listing it as a 3:55sg but the broadcast sheet list it as a 3:23 open Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
[Re: 6bblgt]
#2454452
02/20/18 10:54 AM
02/20/18 10:54 AM
VCODE
White Plains, NY
1971 E-Body: the "014" axle is a 741 case 7260 pinion w/3.23 ratio OPEN & 10" brakes the "015" axle is a 741 case 7260 pinion w/3.23 ratio OPEN & 11" brakes
the "016" axle is a 489 case 7290 pinion w/3.23 ratio OPEN & 10" brakes the "017" axle is a 489 case 7290 pinion w/3.23 ratio Sure-Grip & 10" brakes the "018" axle is a 489 case 7290 pinion w/3.23 ratio OPEN & 11" brakes the "019" axle is a 489 case 7290 pinion w/3.23 ratio Sure-Grip & 11" brakes
Dan, your the man. That's what I been trying to figure out. Exactly what I have. Thanks Bob
[Re: Morty426]
#2454975
02/21/18 06:56 AM
02/21/18 06:56 AM
Posts: 17,514 Las Vegas, NV
6bblgt
Las Vegas, NV
So what is the trigger between getting a "015" vs. a "018" - my 71 340 Challenger is a 4 speed and Bill's 71 cuda 340 is an automatic yet we both have "015" ???? for 1971 E-body 3.23:1 OPEN 8-3/4" rear axle - it looks like it is as simple as small block VS. big block (can't confirm where the 383 2bbl ends up?) 10" brakes = "014" (318 & 340) 741 VS. "016" (383 4bbl, 6bbl, HEMI) 489& 11" brakes = "015" (318 & 340) 741 VS. "018" (383 4bbl, 6bbl, HEMI) 489
[Re: 6bblgt]
#2455075
02/21/18 01:59 PM
02/21/18 01:59 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
So what is the trigger between getting a "015" vs. a "018" - my 71 340 Challenger is a 4 speed and Bill's 71 cuda 340 is an automatic yet we both have "015" ???? for 1971 E-body 3.23:1 OPEN 8-3/4" rear axle - it looks like it is as simple as small block VS. big block (can't confirm where the 383 2bbl ends up?) 10" brakes = "014" (318 & 340) 741 VS. "016" (383 4bbl, 6bbl, HEMI) 489& 11" brakes = "015" (318 & 340) 741 VS. "018" (383 4bbl, 6bbl, HEMI) 489 Cool. That makes sense. Now why did some disk brake cars get 11" rear brakes?
[Re: Alaskan_TA]
#2455472
02/22/18 05:01 AM
02/22/18 05:01 AM
Posts: 1,923 Medina, Ohio
HEMICUDA
Medina, Ohio
That is the 1970 chart as mentioned above. It appears to have been stolen & modified though........ For the record, no one has permission to take images from HH, let alone modify them. Let me get this straight, you "steal" it from Chrysler, put your website watermark on it so it's yours? Oh Please, take your ball and go home.
[Re: HEMICUDA]
#2455623
02/22/18 02:47 PM
02/22/18 02:47 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
That is the 1970 chart as mentioned above. It appears to have been stolen & modified though........ For the record, no one has permission to take images from HH, let alone modify them. Let me get this straight, you "steal" it from Chrysler, put your website watermark on it so it's yours? Oh Please, take your ball and go home. Funny how that works...
