Spool Motor Mounts - Poly or Rubber? #2453514
02/18/18 04:18 PM
02/18/18 04:18 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline OP
P
Need to swap out my spool motor mounts. What are the differences between poly and rubber?
Re: Spool Motor Mounts - Poly or Rubber? [Re: Pntastar69] #2453828
02/19/18 11:08 AM
02/19/18 11:08 AM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I have poly spool mounts on my bb duster. They work fine for Me. Headers fit so tight I couldn't see using the rubber mounts.
Re: Spool Motor Mounts - Poly or Rubber? [Re: Pntastar69] #2453850
02/19/18 12:04 PM
02/19/18 12:04 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
watch what brand mfg poly you might decide to buy, as some have been known to melt with high under hood heat, not a job you want to do twice...
FYI I run the Schumacher Magnum poly-loc motor mounts
