Roller cams, again. #2452187
02/15/18 04:18 PM
02/15/18 04:18 PM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
Continuing with my pursuit of retrofit hydraulic roller B/RB camshafts, this board was immensely helpful with the oil pump drive gear. So.. the next concern...fuel pump pushrod. What should I use for an aftermarket hydraulic roller?
Re: Roller cams, again. [Re: 6PakBee] #2452287
02/15/18 08:54 PM
02/15/18 08:54 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
What's the cam made of? Call the cam maker and ask them.
Re: Roller cams, again. [Re: 6PakBee] #2452462
02/16/18 11:13 AM
02/16/18 11:13 AM
scratchnfotraction Offline
IIRC they have a bronze tip rod to use on billet roller cams.
I agree on ask the maker.
I have had roller cams with a iron gear pressed on (cam cast core?) to use the stock iron intermediate shaft.
and billet that had to have bronze gear.
Re: Roller cams, again. [Re: 71birdJ68] #2452481
02/16/18 12:10 PM
02/16/18 12:10 PM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
Billet cam.
Re: Roller cams, again. [Re: 6PakBee] #2452491
02/16/18 12:28 PM
02/16/18 12:28 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
If the cam is kind of copper color then use a bronze or coated gear, and bronze tip fuel pump push rod.
Re: Roller cams, again. [Re: 6PakBee] #2452641
02/16/18 05:07 PM
02/16/18 05:07 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I used the Comp Cams Bronze tiped fuel pump push rod.
Seemed to be fine, but only had about 500 miles on it when I changed to EFI. Sold the pushrod to a friend, and it still looked brand new.
Re: Roller cams, again. [Re: 451Mopar] #2452811
02/16/18 10:07 PM
02/16/18 10:07 PM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
Thanks everybody, the brass tipped pushrod it is!!
