ecu change 6-8 #2452796
02/16/18 09:41 PM
02/16/18 09:41 PM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
Putting 318 in a car that had a /6 .. do I ave to change the ECU ?. It is complete running car with the 225...1979 plymouth..
Re: ecu change 6-8 [Re: dynamite] #2452804
02/16/18 09:50 PM
02/16/18 09:50 PM
You do not
Re: ecu change 6-8 [Re: RapidRobert] #2452833
02/16/18 11:12 PM
02/16/18 11:12 PM
Originally Posted By RapidRobert
You do not
iagree up
Most of the stock OEM ECU from Mopar had a built in RPM limiter, you may find out after getting the car sorted out that you may want a good after market ECU to allow higher RPM than the stock one, yours, does work
Maybe not if you don't want to rev it over 5500 RPM or so confused shruggy
