oil filters #2452386
02/16/18 12:29 AM
02/16/18 12:29 AM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
read the thread on oil- what oil filters work well on big blocks and don't cause unneeded extra strain on pump?
Re: oil filters [Re: RustyM] #2452393
02/16/18 12:42 AM
02/16/18 12:42 AM
Any racing filter will bypass at a lower pressure and bypass more oil than a conventional filter will shruggy Maybe not a good thing work
The bigger the filter, the more area in the filter it has and the oil will have less resistance to oil flow up work
Years ago I dyno tested the same motor and oil pump with one conventional size oil filter on the pump and then change the pump top to use one remote mounted oil filter, and then two and finally four oil filters mounted in parallel, not in series, and saw no losses or gains on the dyno shock confused
I did learn or remembered later that all the Mopar and Ford type oil filters have built in bypass in them, not like most of the GM style oil filter that are full flow with the bypass in the oil filter adapter bolted into the block work shruggy
My race car motor has a NASCAR race size remote mounted oil filter (like the Fram HP6 size) but I use the Wix brand race filter with a built in bypass up
Re: oil filters [Re: Cab_Burge] #2452395
02/16/18 12:44 AM
02/16/18 12:44 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
I use Baldwin on anything I care about.
'63 Dodge 330
11.19 @ 121 mph
Re: oil filters [Re: GY3] #2452402
02/16/18 01:14 AM
02/16/18 01:14 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
As do I 90 % of the time.
As I recall Hastings was bought out by Baldwin. I could be wrong on that.
My dad always stood by Hastings.
Re: oil filters [Re: NTOLERANCE] #2452410
02/16/18 01:28 AM
02/16/18 01:28 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Wix or Napa Gold for me.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: oil filters [Re: RustyM] #2452430
02/16/18 02:54 AM
02/16/18 02:54 AM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
Re: oil filters [Re: RustyM] #2452549
02/16/18 02:18 PM
02/16/18 02:18 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Jomar Mopar/Ford filter: no bypass ==> LINK
Re: oil filters [Re: pittsburghracer] #2452594
02/16/18 03:27 PM
02/16/18 03:27 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
iagree
Re: oil filters [Re: RustyM] #2452651
02/16/18 05:32 PM
02/16/18 05:32 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
NAPA Gold for a daily driver. I used a System One trash can - the same one - for many years, on the race stuff. Clean it, check it after every weekend. Change the o-rings occasionally. I think it was 45 micron. I loved it. I really like the Clear View Filtration assemblies being sold now. That would be my choice.
I see a lot K&Ns on fuel and professional engines. Don't know the number, I expect at that level, people are having filters made to their spec.
Micron rating needs to be paid attention to. The Wix 51515R and 57003R are 61 micron. Standard Wix is 19. The Fram HP6A is 12. I see street filters down around 10.
I suggest reading the David Reher article referenced in the engine oil thread.
