Page 4 of 5 < 1 2 3 4 5 >
#2455154 - 02/21/18 01:40 PM Re: Ritter Block [Re: Biginchmopar]
DavidDean Offline
Loc: Lubbock,TX
Is the Ritter block Siamese ?
Is the max bore size 4.250 ?
#2455156 - 02/21/18 01:42 PM Re: Ritter Block [Re: Biginchmopar]
Biginchmopar Offline
Loc: Carson City, Nevada
It is Siamese and I think they say 4.220"
#2455159 - 02/21/18 01:51 PM Re: Ritter Block [Re: Biginchmopar]
Al_Alguire Offline
Loc: Rockville MD & Las Vegas
Well you cant argue wanting the biggest bore possible as bore is HP. But weight is also a factor, any idea what the weight difference between the two are? Just curious
#2455168 - 02/21/18 02:15 PM Re: Ritter Block [Re: Al_Alguire]
WHITEDART Offline
Loc: bean town
About 100lb
In the 8s N/A.with Brett miller W8
5.42 1/8
#2455177 - 02/21/18 02:33 PM Re: Ritter Block [Re: Biginchmopar]
Al_Alguire Offline
So in my mind you would need to be able to making enough power to overcome the weight difference to justify the extra weight. Why I have chosen aluminum BB's over the iron brethren. The big difference is the weight difference is larger but the bore potential is the same. BUt that is the logic behind why the Vette has an aluminum SB in it, but we are not limited to a smaller bore because of that choice.
#2455228 - 02/21/18 04:22 PM Re: Ritter Block [Re: Biginchmopar]
All out race car deal I would go Aluminum.
This thing is getting there quick, at least the engine part. realcrazy
beer
#2455327 - 02/21/18 07:43 PM Re: Ritter Block [Re: Biginchmopar]
LA360 Offline
Loc: Melbourne , Australia
The Ritter block in it's aluminium form is the same casting as the iron version. It's not a specific pattern, I'm not even sure if they've allowed for the different shrinkage rates of the two materials.
I'd want to see some more material in the casting, ribs etc. That's just a personal preference of mine. I think for most of us, the weight saved in an aluminium block is more of a benefit. Those chasing every last piece of HP, in a car they have to add ballast too, you'd go Iron.
Alan Jones
#2455347 - 02/21/18 08:22 PM Re: Ritter Block [Re: LA360]
pittsburghracer Offline
Slowride
Loc: PA.
A lot of guys go with aluminum for ease of repairing the block when all heck break loose. Lots of junk mega blocks still laying around
1970 Duster
Edelbrock headed 408
6.143@110.89 mph
9.73@135.05 mph shifting at 6700 RPM
422 Indy headed small block
6.001@113.27mph
9.44@138.23
Untitled by John Cadamore, on Flickr
#2455383 - 02/21/18 09:33 PM Re: Ritter Block [Re: Biginchmopar]
DavidDean Offline
Loc: Lubbock,TX
It’s too bad the max bore size of the aluminum is 4.120. Does any one know the price ?
#2455385 - 02/21/18 09:42 PM Re: Ritter Block [Re: Biginchmopar]
69 lawndart Offline
Loc: Kansas, Topeka
Mine is 4.155", I would say 4.185" is about max bore, I think the prototype aluminum block is 4.185". There is a lot of material around the cylinders in this block. I was told that the castings were the same. The weight on mine is 107 lbs. with sleeves and main caps. I need to add for a NA motor.
Edited by 69 lawndart (02/21/18 09:43 PM)
#2455392 - 02/21/18 10:07 PM Re: Ritter Block [Re: Cab_Burge]
RylisPro Offline
Loc: NorCal
Originally Posted By Cab_Burge
Be careful of what you wish for tsk whistling work
N/A iron blocks, even super charged, will run faster than the same parts in a aluminum block in the 1/4 mile in the same car weighing the same shruggy
All good Cab!
You want an aluminum block for track days and road racing. I got an all aluminum Gen3 instead. 600hp at the crank is plenty scary enough when going around a corner!
/Drive
Instagram: @rylispro
YouTube:RylisPro
www.rylispro.com
925-214-9192
Tremec T56 Magnums & Quick Time bells
Lightened Billet Steel Flywheels
Prefix Performance
#2458434 - 02/27/18 12:40 PM Re: Ritter Block [Re: Biginchmopar]
Just a quick update. After making a few calls and talking to the guys that are way deep into these small blocks, I have decided to take the block to Quarter Mile Performance (QMP) is Southern California. They have all the tools to do what I want plus they have already worked on a few of these blocks in the past so we will get their opinion as well.
These are all good things and I'll share what we find when it is finished being machined.
#2458487 - 02/27/18 02:35 PM Re: Ritter Block [Re: Jason B]
Originally Posted By Jason B
We did exactly that... we opened up the cam tunnel to increase drain back. We are going to run a similar setup as White Dart using a Daily wet sump.
White Dart is a great source of help and information. I will be starting a thread as soon as ours starts going back together! Hopefully will be posting pictures in a few weeks good luck and if you need any help let us know.
Thanks Jason!
I'll be in touch for sure, lots of little details need to be addressed. up
#2458490 - 02/27/18 02:43 PM Re: Ritter Block [Re: Biginchmopar]
Al_Alguire Offline
Hard to go wrong with the QMP crew
#2458555 - 02/27/18 05:05 PM Re: Ritter Block [Re: Al_Alguire]
WHITEDART Offline
Loc: bean town
I'm going to say good choice.. it will require some patience because they are very busy but I assure you it will be worth the wait.. when you get their since you're a paying customer ask for a tour of the shop.. you will be surprised at the names on blocks and boxes of parts that you see.. everything from shops that say they do everything in house to maybe even some top 10 Pro Stock teams. I know you had some other options on block transportation.. but definitely worth a field trip
5.42 1/8
#2458600 - 02/27/18 07:10 PM Re: Ritter Block [Re: WHITEDART]
WHITEDART Offline
Loc: bean town
A sneak peek inside qmp North
5.42 1/8
#2458601 - 02/27/18 07:11 PM Re: Ritter Block [Re: WHITEDART]
WHITEDART Offline
Loc: bean town
And for those that know about honing
5.42 1/8
#2459577 - 03/01/18 05:34 PM Re: Ritter Block [Re: WHITEDART]
LA360 Offline
They made a substantial investment (around $100K) in their honing equipment. Definitely a higher end machine shop
Alan Jones
#2459579 - 03/01/18 05:45 PM Re: Ritter Block [Re: LA360]
WHITEDART Offline
Loc: bean town
I think you meant to say hone head and diamonds whistling.. and actually I think that was only for the old head and stones.
They have substantially better stuff than that now.. I think if you have a Target temperature that you can operate the Motor Inn he can hone the block at that temperature..
Edited by WHITEDART (03/01/18 05:52 PM)
5.42 1/8
#2459584 - 03/01/18 05:56 PM Re: Ritter Block [Re: Al_Alguire]
Thumperdart Offline
Loc: State of confusion
I would of given Pettis a call unless Jason doesn't have the experience w/those......... thumbs
72 Dart 470 n/a BB stroker street car `THUMPER`.....Check me out on FB for stories, videos and lots of carb pics..........760-900-3895........
25,339 Registered Members
190,139 Topics
Most users ever online: 1,417 @ 06/18/18 08:39 PM
Mopars at the Patch 2018
by 11secdart
Yesterday at 09:30 PM
Mopars at the Patch
by 11secdart
Yesterday at 09:28 PM
My Thumper inspired dominator....
by dartman366
Yesterday at 09:03 PM
Recommend a resto shop for my wife's 64?
by not_a_charger
Yesterday at 08:50 PM
