Re: Ritter Block
[Re: Biginchmopar]
#2453440
02/18/18 01:16 PM
02/18/18 01:16 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Did you bolt a timing cover to it?
Set a head gasket and check if it would seal and if the water passages line up?
I would also screw studs in it and see if the heads can go on
I have witnessed Shilohs (whitedart) problems and hope yours is trouble free.
"Just a Bracket car dressed up like a streetcar"
Re: Ritter Block
[Re: Biginchmopar]
#2453442
02/18/18 01:21 PM
02/18/18 01:21 PM
Posts: 361 Canada
onig
Canada
Curious, how did you check the lifter angles?
69 Dart
Re: Ritter Block
[Re: onig]
#2453502
02/18/18 03:52 PM
02/18/18 03:52 PM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
Curious, how did you check the lifter angles? I used some lifters and did some measurements. I’ll reconfirm these once I get them to the shop with the fixture that we use to do lifter bushings.
Re: Ritter Block
[Re: Just-a-dart]
#2453503
02/18/18 03:55 PM
02/18/18 03:55 PM
Biginchmopar
Carson City, Nevada
I have witnessed Shilohs (whitedart) problems and hope yours is trouble free. Not yet, but I will soon (timing cover) Studs and heads yes, gasket no
Re: Ritter Block
[Re: WHITEDART]
#2453549
02/18/18 05:46 PM
02/18/18 05:46 PM
Posts: 11,524 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
On another note I'm not saying it's mandatory.. but I think bushing the lifters is a smart move with the way that he has drilled the oil Galley through the center of the lifter bore.. it's very easy to get in a situation where the lifter uncovers the oil Passage I'm not familiar with these and this may be a dumb question, but if the lifter bores interrupt the galley 100% and you bush them and block the galley, how is the crank oiled? Right side conventional and left side drilled through the center?
Re: Ritter Block
[Re: CMcAllister]
#2453698
02/18/18 11:42 PM
02/18/18 11:42 PM
Biginchmopar
Carson City, Nevada
On another note I'm not saying it's mandatory.. but I think bushing the lifters is a smart move with the way that he has drilled the oil Galley through the center of the lifter bore.. it's very easy to get in a situation where the lifter uncovers the oil Passage I'm not familiar with these and this may be a dumb question, but if the lifter bores interrupt the galley 100% and you bush them and block the galley, how is the crank oiled? Right side conventional and left side drilled through the center? These blocks have priority oiling to the mains. The lifter bushings I’m going to use will have groves on the outside to pass excess oil by.
Re: Ritter Block
[Re: Biginchmopar]
#2454399
02/20/18 03:07 AM
02/20/18 03:07 AM
Posts: 1,505 TN
SCATPACK 1
TN
With the Limited oil return on the Block if you're doing a wet sump I would also recommend external drain Backs from the head to the oil pan this enables air to come up so oil can go down in other locations Let me ask this, wet sump, what about drilling holes from the cam tunnel valley to the crankshaft, I know, I know, windage, it's an issue but is it really on a deal were you're not looking for every last HP? I believe on a wet sump I would do a lot more work on oil return. I'll do that on one of the engines I'm going to build because it will be wet sump. I will look into all options but putting hole into the cam tunel to the crankshaft area would help. It might also help to return oil from the valley even though it is open in the back. I will keep you guys posted. What about drilling a 1/4 inch hole next to each main saddle. That way any oil that drains back would be down the side of the main saddle and not splashing around too much. Would require holes drilled next to #2, #3, and #4 mains. HAH. Never mind, i see you already handled the oil drain issue. Treed again.
Old Geezer Racing
Re: Ritter Block
[Re: SCATPACK 1]
#2454423
02/20/18 05:30 AM
02/20/18 05:30 AM
Posts: 6,136 Melbourne , Australia
LA360
They certainly look better, the rear cap is markedly improved.
I have a couple of XR2 blocks for P7 heads, they're earlier blocks. Once I've recovered from a recent surgery, I'll be measuring them. I have a feeling the lifter bores are out of position, based on my initial inspections.
Alan Jones
Re: Ritter Block
[Re: Cab_Burge]
#2454631
02/20/18 04:15 PM
02/20/18 04:15 PM
Posts: 20,158 PA.
pittsburghracer
"Little"John
"Little"John
PA.
But the car won’t weight the same. Lol.
Re: Ritter Block
[Re: Cab_Burge]
#2454643
02/20/18 04:51 PM
02/20/18 04:51 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I know that the OP's block is cast iron due to the unthreaded freeze plug ports and lack of sleeves. Is your block above aluminum? If so that is so cool! I had always wanted an all aluminum small block Mopar! Be careful of what you wish for N/A iron blocks, even super charged, will run faster than the same parts in a aluminum block in the 1/4 mile in the same car weighing the same Which means they make more power. Ive been told by engine guys that you need to "get after" an aluminum block combination more so than an iron block. And then there's the extra expense. Some of us have a finite budget and want to spread it around past one engine or one car.
Re: Ritter Block
[Re: J_BODY]
#2454860
02/20/18 11:52 PM
02/20/18 11:52 PM
Posts: 43,118 Bend,OR USA
Cab_Burge
Certain heads up classes out here have minimum weights ....so you'd prefer not to put the weight where YOU want it? The car I'm talking about had ballast on the front bumper with the aluminum block, they moved it from there and move it further back to keep the front to rear ratio % the same for traction, they had to add over 400 lbs. to the car make the minimum weights I wish I could afford to build a car like that, but I'm not
