Re: 1980 F-body disc brakes on a 1970 B-body. What swaps over?
[Re: Montclaire]
#2452767
02/16/18 08:31 PM
02/16/18 08:31 PM
Posts: 25,729 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If you want the car to operate exactly the same but with unicast discs, then you need the 73-76 A-body or 73-74 E-body spindle, which is exactly the same height as what you have now. And you keep saying they're readily available...maybe in your neighborhood, not mine.
[Re: Alaskan_TA]
#2452777
02/16/18 09:05 PM
02/16/18 09:05 PM
Posts: 2,094 central texas
krautrock
central texas
The car has 10" manual drums now.
A pal is selling a rusty 1980 F-body, but the brakes still work, so......
That is why I am asking.
I have already agreed to buy it, but the final price is flexible depending on what all I can use. you can use the spindles, just do the research so you get the right calipers and hoses (or just order them from doctor diff). if your car has a factory sway bar then you want to mount the calipers to the rear, no sway bar or aftermarket, then you can front mount the calipers (swapping the spindles on each side) and the brake hose routing will be cleaner... if the calipers on the donor car are good, you can just use all that stuff and mount the calipers on the rear like factory. i would buy some firm feel upper control arms though so you can run more modern alignment specs since we aren't all driving on bias ply tires anymore like the cars were originally spec'd for...
[Re: Alaskan_TA]
#2452806
02/16/18 09:54 PM
02/16/18 09:54 PM
Posts: 2,070 CA
crackedback
CA
Go with the FMJ stuff, it will work fine. I've done a bunch of cars with both A and FMJ stuff, none drove as through they were going to toss you off the road from bump steer. One had about 50K miles on an FMJ swap when I sold it. The scare mongers still exist from the article written in the 90's where IIRC, the author has said he'd never heard of a ball joint failure directly related to the additional spindle height. A friend ran the numbers and the additional angle at ball joint was 1.5* at both ends IIRC, 3* total through the swing. I'm pretty sure the ball joint tolerances were not built where an additional 1.5* was going to jam a stud to housing. This garbage is like a scary movie that isn't so scary...
[Re: Alaskan_TA]
#2452853
02/16/18 11:47 PM
02/16/18 11:47 PM
Posts: 29,650 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Got it. Thanks again all. I have an appointment to see the brakes in person in the morning.
[Re: Montclaire]
#2453013
02/17/18 01:06 PM
02/17/18 01:06 PM
Posts: 5,386 Pikes Peak Country
TC@HP2
Pikes Peak Country
1980 F-body power disc brakes on a 1970 manual drum B-body chassis. What swaps over & what if any additional parts would be needed to convert them?
15" wheel car.
Thanks! You need everything in between the ball joints. Someone correct me if I'm wrong but I believe if you want to use 11.75 rotors you need B-body Cordoba caliper adapters too. These are available repopped from Dr Diff and others.
Kevin True, but the 10.5 F body units are not too shabby for a cruiser. The F-body spindles are not the correct height. They are taller and will skew the suspension geometry. You want 73-76 A-body or 73/74 E-body. Uhhh, how long have you been on moparts? This topic has been beat to death on here every few years since the mid 1990s from every angle possible. Significant research has been done into it and for all intent, it is a non-issue for all but a few small minority.
[Re: Alaskan_TA]
#2453446
02/18/18 01:34 PM
02/18/18 01:34 PM
Posts: 19,310 north of coder
moparx
one thing you may run into using the F-body booster is, it might be too big in diameter causing interference with ????. you may also have to modify the firewall hole and the booster mounting holes. with that said, i used a diplomat booster when i switched over to discs on my 64 belvedere. i believe it is real close to the diameter of the F-body. i had to enlarge the rod through hole, and drill two extra holes in the firewall to mount the booster. there wasn't anything in the way to cause interference, as this was a low option car. just some things to consider. and yes, i used the taller spindles with no issues what so ever. if anyone would read up on roll couple and handling issues, the taller spindles would be the ones they would only consider. remember, ALL factory suspension systems [with only a few exceptions such as sporty, handling types] are a COMPROMISE so the masses can "drive" the car without getting into trouble. the factory engineers spend big bucks on design as has been stated, but for "joe average" ONLY, not for hot rod or sports car guys like us. this does not in any way reflect on the latest stuff out there today, only the stuff available "back in the day".
[Re: Alaskan_TA]
#2457938
02/26/18 04:50 PM
02/26/18 04:50 PM
Posts: 512 Niwot, CO Formerly denn...
dynorad
I did this swap about 15 years ago on a 67 Satellite. The only effect of the taller spindle is a little more camber gain as the suspension compresses. The brake hose wants to be on the opposite side of the spindle so I fabbed up a bracket in the correct new location (such that the brake hose passes through the spindle pivot axis) and made a short section of hard line to connect from the new bracket to the old. Worked great.
