recommend a clutch kit for a 2001 ram 1500? #2440725
01/25/18 09:24 PM
01/25/18 09:24 PM
Southern CA
Colin Frolick Offline OP
Southern CA
Hi, the throwout bearing on my truck is getting noisy so I'm looking for a replacement. The truck is an '01 ram 1500 4x4 with a 5.2L and the NV3500 gearbox. I've read something about the t/o bearings being partly plastic and there may be a better one? I have no idea. Any of you all's thoughts I'd really appreciate
Cheers
Re: recommend a clutch kit for a 2001 ram 1500? [Re: Colin Frolick] #2440760
01/25/18 11:02 PM
01/25/18 11:02 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
I dont care for perfection/brute power or zoom branded clutches... made in china.
Anything from Valeo, sachs, LuK, or AMS is usually fine. They are mostly made in mexico, sometimes the friction disc's are from Korea.
OEM clutches are my preferred installation but they can be ungodly expensive and with chrysler anymore who knows what the hell your really getting unless you can see it before buying it.
Re: recommend a clutch kit for a 2001 ram 1500? [Re: Colin Frolick] #2452361
02/15/18 11:19 PM
02/15/18 11:19 PM
Southern CA
Southern CA
so to follow up... bought a Sachs kit for $170.
box says made in China, plate says Korea, fwiw
old t/o bearing was trashed at 85k miles, clutch was not bad.
New clutch inspires wheelspin up
