Spark plug wire routing??? #2452143
02/15/18 02:50 PM
02/15/18 02:50 PM
Canada
onig Offline OP
onig  Offline OP
Canada
Has anybody tried running the spark plug wire to the same cylinder as the COP, instead of having it going to it's companion cylinder. I have started working on a 04 5.7 Hemi from a Durango and want to clean up the look of the engine when the time comes for this aspect of it.
This is the idea that I had.
69 Dart
Re: Spark plug wire routing??? [Re: onig] #2452151
02/15/18 03:03 PM
02/15/18 03:03 PM
Canada
onig Offline OP
onig  Offline OP
Canada
69 Dart
Re: Spark plug wire routing??? [Re: onig] #2452345
02/15/18 10:55 PM
02/15/18 10:55 PM
cbusters Offline
cbusters  Offline
If you are going to run an MSD Hemi 6 to handle the ignition system, I believe you will have to switch coils. I think the wiring harness was discontinued for the early coils. Check before you invest time in the mod.
If not, disregard.
Re: Spark plug wire routing??? [Re: onig] #2452391
02/16/18 12:35 AM
02/16/18 12:35 AM
Canada
onig Offline OP
onig  Offline OP
Canada
Will be using Megasquirt.
69 Dart
Re: Spark plug wire routing??? [Re: onig] #2453198
02/17/18 09:07 PM
02/17/18 09:07 PM
okla.
sam64 Offline
sam64  Offline
okla.
I have both of my carbed 5.7's like that,Taylor makes wires for that.
Re: Spark plug wire routing??? [Re: onig] #2453415
02/18/18 12:31 PM
02/18/18 12:31 PM
Canada
onig Offline OP
onig  Offline OP
Canada
OK great, thanks.
69 Dart
