A body hood hinge removal #245184
03/06/09 06:01 PM
03/06/09 06:01 PM
Freeport, Pa
W
whiskeyrunner Offline OP
W
Freeport, Pa
im taking my hood hinges off of my duster and wanted to know the best way to go about it. i looked through the tech archives but didn't come across anything. any help is appreciated!
thanks!
Re: A body hood hinge removal [Re: whiskeyrunner] #245185
03/06/09 06:24 PM
03/06/09 06:24 PM
Arkansas
340727dart Offline
340727dart  Offline
Arkansas
Some will tell you to remove the inner fenders and go in that way.
I was able to remove the washer that holds the hinge to the pivot point by going in behind the open door. It put up a good fight but I eventually got it off and was able to reuse it.
Your life is not my fault.
My life is none of your business.
Speech is free only if you agree with those in control.
Re: A body hood hinge removal [Re: 340727dart] #245186
03/06/09 06:42 PM
03/06/09 06:42 PM
Colorado
Leadfoot Offline
Leadfoot  Offline
Colorado
Underneath the undercoating in the wheelwell is an access panel. You can unbolt it from there but I've never tried to remove a hinge that way. I believe it's possible though.
Re: A body hood hinge removal [Re: whiskeyrunner] #245187
03/06/09 07:42 PM
03/06/09 07:42 PM
STEELER NATION!!!
Skeez Offline
Pretty in Pink
Skeez  Offline
Pretty in Pink
STEELER NATION!!!
Take the fenders off. Easiest way to access them without going completely insane Depending on how old the clips are that hold them on, it's better to take a wire cutter and just cut them off, and get new ones when you re-install them. If you do choose to go at them from the door jamb, make sure there are no little kids around
Re: A body hood hinge removal [Re: Skeez] #245188
03/06/09 08:00 PM
03/06/09 08:00 PM
Freeport, Pa
W
W
Freeport, Pa
thanks guys...i just removed that panel.
Re: A body hood hinge removal [Re: Skeez] #245189
03/06/09 08:01 PM
03/06/09 08:01 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
You might get lucky removing them without pulling the fenders but there's a chance the hinges may not slide straight off the pins once the retainers are cut due to other interference. Mine had to be tilted at an angle to get them on and off the top pin and there's no way to do that with the fenders on.
Re: A body hood hinge removal [Re: 70Duster440] #245190
03/07/09 06:25 PM
03/07/09 06:25 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
Pull the inner panel (splashield)
You can pop the spring off with a large screwdriver BUT it's not necessary (it sometimes helps relax the hinges allowing them pull off the pins easier.
Mask off the inner fender, hinge area
Cut off the retaining rings
Reach in with a long screwdriver and gently pry the hinges off the pins
It WILL take some time and finess but you will get them off without pulling the fender or door.
It is a frustrating job but alot easier them pulling sheetmetal.
