Re: How Many Feet of Battery Cable? [Re: markz528] #2452522
02/16/18 01:08 PM
02/16/18 01:08 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
There are nice. They work just like a collet. Heat shrink over the top.
https://www.speedwaymotors.com/Taylor-21405-Top-Post-Battery-Cable-Terminal-End-Kit-2-Pack,93194.html
Doug
Re: How Many Feet of Battery Cable? [Re: markz528] #2452645
02/16/18 05:18 PM
02/16/18 05:18 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I don't need the battery ends, using the pre-made battery cables for positive to cut-off switch, and negative to chassis. I run two of the pre-made lug ended ground cables from each side frame to block.
The welding cable is from the cut-off switch to a firewall mounted bulkhead connector.
Curious if I should put a 150-200A circuit breaker between the battery and cut-off switch to protect the run of welding cable and cable to started, or would that add extra resistance to the circuit?
Re: How Many Feet of Battery Cable? [Re: markz528] #2452840
02/16/18 11:23 PM
02/16/18 11:23 PM
I worked for a fairly big telephone company for many years, they furnished us with multiple size crimpers for splicing the smaller gauge telephone wires up
I wish I had been able to bag some of the larger crimpers and connectors for 000 down to maybe #8 gauge, but I didn't whiney
The alternative solder and heat shrink works good for me up
A lot better than the cheaper crimp on ends you can buy from your general automotive parts store shruggy I buy Belden connectors when I can get them up
Re: How Many Feet of Battery Cable? [Re: markz528] #2452858
02/16/18 11:54 PM
02/16/18 11:54 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I'm crimping mine, my brother has the correct crimpers that he used when he worked in coal mines.
