273 rockers #2449139
02/09/18 04:25 PM
02/09/18 04:25 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
To change the factory style 273 rocker arms to a adjusting screw and lock nut, what if anything needs to be done to the rocker arm?
Re: 273 rockers [Re: DusterKid] #2449148
02/09/18 04:41 PM
02/09/18 04:41 PM
pennsylvania
poboyengineering Offline
pennsylvania
Just spot face the area where the nut will rest.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: 273 rockers [Re: DusterKid] #2449704
02/10/18 07:36 PM
02/10/18 07:36 PM
Keymar, MD
Keymar, MD
I'm assuming the spot face is to help the nut sit flush? Does it have to be done on a lathe or could a sanding belt be good enough?
Re: 273 rockers [Re: DusterKid] #2449727
02/10/18 08:15 PM
02/10/18 08:15 PM
pennsylvania
pennsylvania
I did mine on a mill. I suppose you could do it on a drill press with a center cutting end mill. And yes, it's to give the nut a flat to tighten against.
Re: 273 rockers [Re: DusterKid] #2449731
02/10/18 08:17 PM
02/10/18 08:17 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Where do you buy the replacement adjusters? I got a set of those rockers in my junk.
Re: 273 rockers [Re: DusterKid] #2449739
02/10/18 08:37 PM
02/10/18 08:37 PM
pennsylvania
pennsylvania
Isky sells them, among others.
Re: 273 rockers [Re: DusterKid] #2450498
02/12/18 02:40 AM
02/12/18 02:40 AM
MO
cdp Offline
cdp  Offline
MO
https://www.pushrods.net
The factory adjusters are a tapered thread. All you have to do is chase them with a good 5/16-18 or 3/8-24 tap (can't remember which) to finish them out.
I've done 1 set already, but haven't spot faced them yet.
Re: 273 rockers [Re: DusterKid] #2451733
02/14/18 05:37 PM
02/14/18 05:37 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My old Sig Ersons were interference fit.They finally started backing off after 30 plus years.Bought MP adjusters and they fit perfect.Still running them and adjust maybe once every 2 years.Rocky
Chrysler Firepower
