#2451564 - 02/14/18 02:02 AM Rear window replacement
wyldebill Offline
Loc: Midland,Tx
I'm needing to replace the rear window in my 73 d100. Looking on eBay, I can only find 75-93. Is there really a difference in the 72-75 rear glass? Thanks Bill
#2451574 - 02/14/18 05:04 AM Re: Rear window replacement [Re: wyldebill]
buildanother Offline
Loc: chicagoland,usa
Maybe it's a matter of using the correct gasket, but I have seen 2 different sized windows for rear of those trucks.
#2452942 - 02/17/18 01:40 AM Re: Rear window replacement [Re: wyldebill]
wyldebill Offline
Loc: Midland,Tx
No one else?
#2453004 - 02/17/18 09:28 AM Re: Rear window replacement [Re: wyldebill]
58pwrwgn Offline
Loc: MN
Did you try doing a search. This topic came up before somewhere about different backglass and sliders. If you are looking at sliders I think the aftermarket is based on the plain backglass gasket. Don't know if the body opening changed size.
Edited by 58pwrwgn (02/17/18 09:34 AM)
#2454077 - 02/19/18 04:18 PM Re: Rear window replacement [Re: wyldebill]
begood Offline
Loc: Michigan
Yes there is a difference, the earlier back windows are quite a bit smaller. That is why they are so hard to find.
THERE IS NO SUCH THING, AS TOO MUCH HORSEPOWER
25,737 Registered Members
192,815 Topics
Need more rear spring
by mickm
02/15/19 01:37 PM
Lexan
by SpeedRacer
02/15/19 01:25 PM
Current Rockauto Discount Code
by TJ2
02/15/19 01:24 PM
74 360 compression boost
by MrMayhem
02/15/19 01:11 PM
