Re: Rear window replacement
[Re: wyldebill]
#2453004
02/17/18 12:28 PM
02/17/18 12:28 PM
Posts: 136 MN
58pwrwgn
MN
Did you try doing a search. This topic came up before somewhere about different backglass and sliders. If you are looking at sliders I think the aftermarket is based on the plain backglass gasket. Don't know if the body opening changed size.
[Re: wyldebill]
#2454077
02/19/18 07:18 PM
02/19/18 07:18 PM
Posts: 1,189 Michigan
begood
I'm needing to replace the rear window in my 73 d100. Looking on eBay, I can only find 75-93. Is there really a difference in the 72-75 rear glass? Thanks Bill Yes there is a difference, the earlier back windows are quite a bit smaller. That is why they are so hard to find.
THERE IS NO SUCH THING, AS TOO MUCH HORSEPOWER
