Speed sensor - pinion yoke #2451314
02/13/18 06:59 PM
02/13/18 06:59 PM
AndyF Offline OP
AndyF  Offline OP
I think I have this all figured out now. I upgraded my Strange S60 with a new billet yoke and added a 8 magnet collar so I can measure the speed of the driveshaft. I couldn't find a mounting bracket anywhere so I just designed my own from stainless.
I ended up going with a MSD 2348 sensor since it was less expensive than the Holley sensor. I'm sure there are really cheap sensors available from DigiKey or some place like that but I stayed with the name brands.
This MSD sensor is kind of nice since it includes a light that tells you if the sensor is working. The light goes off when the sensor "sees" the magnet. I double checked with a voltmeter and the sensor is sending a signal each time a magnet passes under it. So I think this item is ready to go.
I'm going to make up some extra brackets and put them on the website. They only fit the Dana 60 with the Strange magnet collar.
Re: Speed sensor - pinion yoke [Re: AndyF] #2451336
02/13/18 07:21 PM
02/13/18 07:21 PM
Canada
onig Offline
onig  Offline
Canada
You make some pretty nice stuff Andy.
69 Dart
Re: Speed sensor - pinion yoke [Re: AndyF] #2451358
02/13/18 07:47 PM
02/13/18 07:47 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
As always look great. I like the sensor with the light, easy trouble shooting should there be an issue.
68 Barracuda Formula S 340
Re: Speed sensor - pinion yoke [Re: AndyF] #2451385
02/13/18 09:17 PM
02/13/18 09:17 PM
Texas
RustyM Offline
RustyM  Offline
Texas
Andy: I couldn't find where you listed that magnet assembly and I swear i saw it listed-am i getting senile and seeing things that were never there?
could you re- list if you don't mind- thanks
Re: Speed sensor - pinion yoke [Re: AndyF] #2451409
02/13/18 10:12 PM
02/13/18 10:12 PM
AndyF Offline OP
AndyF  Offline OP
Magnet collar and yoke are from Strange. DoctorDiff can get them for you or you can order them from Summit. Off the shelf parts. Same with the MSD sensor. You can get the little stainless steel bracket from DoctorDiff.
Re: Speed sensor - pinion yoke [Re: AndyF] #2451432
02/13/18 10:57 PM
02/13/18 10:57 PM
Texas
RustyM Offline
RustyM  Offline
Texas
thank you
Re: Speed sensor - pinion yoke [Re: AndyF] #2451442
02/13/18 11:13 PM
02/13/18 11:13 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I put the collar on my output shaft of my trans. Drilled and tapped the tailshaft and mounted it that way. Just another option for those in need.
Re: Speed sensor - pinion yoke [Re: AndyF] #2451453
02/13/18 11:32 PM
02/13/18 11:32 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I bought all my sensors from Race Pak,I wasn't sure if other sensors were compatible so I took the easy way.I have never found a mounting bracket so I found some scrap aluminum in the garage and fabbed one up.These sensors are probably the same,the O/2 is Bosch and get them at any parts store.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Speed sensor - pinion yoke [Re: onig] #2451800
02/14/18 07:46 PM
02/14/18 07:46 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Looks great Andy.
Don
