#2451314 - 02/13/18 03:59 PM Speed sensor - pinion yoke
AndyF Offline
Loc: Oregon
I think I have this all figured out now. I upgraded my Strange S60 with a new billet yoke and added a 8 magnet collar so I can measure the speed of the driveshaft. I couldn't find a mounting bracket anywhere so I just designed my own from stainless.
I ended up going with a MSD 2348 sensor since it was less expensive than the Holley sensor. I'm sure there are really cheap sensors available from DigiKey or some place like that but I stayed with the name brands.
This MSD sensor is kind of nice since it includes a light that tells you if the sensor is working. The light goes off when the sensor "sees" the magnet. I double checked with a voltmeter and the sensor is sending a signal each time a magnet passes under it. So I think this item is ready to go.
I'm going to make up some extra brackets and put them on the website. They only fit the Dana 60 with the Strange magnet collar.
#2451336 - 02/13/18 04:21 PM Re: Speed sensor - pinion yoke [Re: AndyF]
onig Offline
Loc: Canada
You make some pretty nice stuff Andy.
69 Dart, The BB is now gone, Soon to be Gen 3 Hemi...
#2451358 - 02/13/18 04:47 PM Re: Speed sensor - pinion yoke [Re: AndyF]
Bad340fish Offline
Loc: Tulsa OK
As always look great. I like the sensor with the light, easy trouble shooting should there be an issue.
68 Barracuda Formula S 340
#2451385 - 02/13/18 06:17 PM Re: Speed sensor - pinion yoke [Re: AndyF]
RustyM Offline
Loc: Texas
Andy: I couldn't find where you listed that magnet assembly and I swear i saw it listed-am i getting senile and seeing things that were never there?
could you re- list if you don't mind- thanks
#2451409 - 02/13/18 07:12 PM Re: Speed sensor - pinion yoke [Re: AndyF]
AndyF Offline
Loc: Oregon
Magnet collar and yoke are from Strange. DoctorDiff can get them for you or you can order them from Summit. Off the shelf parts. Same with the MSD sensor. You can get the little stainless steel bracket from DoctorDiff.
#2451432 - 02/13/18 07:57 PM Re: Speed sensor - pinion yoke [Re: AndyF]
RustyM Offline
Loc: Texas
thank you
#2451442 - 02/13/18 08:13 PM Re: Speed sensor - pinion yoke [Re: AndyF]
J_BODY Offline
Loc: aZLiViN
I put the collar on my output shaft of my trans. Drilled and tapped the tailshaft and mounted it that way. Just another option for those in need.
#2451453 - 02/13/18 08:32 PM Re: Speed sensor - pinion yoke [Re: AndyF]
hemi-itis Offline
Loc: Great Neck,LI,new york
I bought all my sensors from Race Pak,I wasn't sure if other sensors were compatible so I took the easy way.I have never found a mounting bracket so I found some scrap aluminum in the garage and fabbed one up.These sensors are probably the same,the O/2 is Bosch and get them at any parts store.
HEMI-ITIS has no cure. My condition is fully BLOWN!!!
New best 60ft,, 1.42,1/8, 6.0 @117,, 9.38 @146.75 with 6 lbs boost @3700 lbs
#2451800 - 02/14/18 04:46 PM Re: Speed sensor - pinion yoke [Re: onig]
cudadon Offline
Loc: New Lenox IL
Looks great Andy.
Don
25,696 Registered Members
196,730 Topics
Are cassettes making a comeback?
by DUFFMAN
01/18/19 10:34 PM
Indoor (home) emergency heating, kerosene, propane, other??
by A12
01/18/19 10:31 PM
Basic ignition question, using MSD-6AL and MSD-8680 boxes
by Fab64
01/18/19 10:29 PM
318 head flow
by skrews
01/18/19 09:35 PM
