1970 cuda / 6.4 hemi with a 6 speed manual HELP!!!! #2440747
01/25/18 10:24 PM
01/25/18 10:24 PM
Harrisville,PA
GRAYBO Offline OP
GRAYBO  Offline OP
Harrisville,PA
Putting a 6.4 hemi with a 6 speed tranny in a 1970 cuda. Put an altercation front end. Put engine and tranny in(kinda). and tranny hits floor bad. How much needs cut out of the original trans hump? Thanks
Re: 1970 cuda / 6.4 hemi with a 6 speed manual HELP!!!! [Re: GRAYBO] #2440765
01/25/18 11:21 PM
01/25/18 11:21 PM
S.E. Missouri
AeroMonte Offline
AeroMonte  Offline
S.E. Missouri
I have a pic of the 71 Cuda I'm doing with the floor cut for the 6 speed swap. It's to big to post here though. I've put a Hellcat engine in the one I'm doing.
Re: 1970 cuda / 6.4 hemi with a 6 speed manual HELP!!!! [Re: AeroMonte] #2440773
01/25/18 11:34 PM
01/25/18 11:34 PM
Harrisville,PA
GRAYBO Offline OP
GRAYBO  Offline OP
Harrisville,PA
Could you send it to my email? Graybo@zoominternet.net.
would be greatly appreciated. Thanks.
Re: 1970 cuda / 6.4 hemi with a 6 speed manual HELP!!!! [Re: GRAYBO] #2440803
01/26/18 12:43 AM
01/26/18 12:43 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Back through the torsion bar crossmember needs to be removed. The 6spd swap is not even close to a bolt-in swap on an ebody...
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: 1970 cuda / 6.4 hemi with a 6 speed manual HELP!!!! [Re: GRAYBO] #2440809
01/26/18 12:57 AM
01/26/18 12:57 AM
S.E. Missouri
AeroMonte Offline
AeroMonte  Offline
S.E. Missouri
Sent you some pics in an email and yes the torsion bar crossmember needs cut also. I had to make my own trans cross member from scratch.
Re: 1970 cuda / 6.4 hemi with a 6 speed manual HELP!!!! [Re: GRAYBO] #2440821
01/26/18 01:38 AM
01/26/18 01:38 AM
Harrisville,PA
GRAYBO Offline OP
GRAYBO  Offline OP
Harrisville,PA
Ed, Thanks for the pics. this will help. Anyone else doing this build got pics?????? Thanks
Re: 1970 cuda / 6.4 hemi with a 6 speed manual HELP!!!! [Re: GoodysGotaCuda] #2440822
01/26/18 01:40 AM
01/26/18 01:40 AM
Harrisville,PA
GRAYBO Offline OP
GRAYBO  Offline OP
Harrisville,PA
goodys, you got any pics or advise? Thanks
Re: 1970 cuda / 6.4 hemi with a 6 speed manual HELP!!!! [Re: GRAYBO] #2440840
01/26/18 02:32 AM
01/26/18 02:32 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I haven't got that far on mine yet or I'd post pics. Seems photobucket has killed off all the threads with pics of installs. I saw lots of pics on one of the e-body sights if your a member there... not sure if I can post links to other sites.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 1970 cuda / 6.4 hemi with a 6 speed manual HELP!!!! [Re: GRAYBO] #2440847
01/26/18 02:56 AM
01/26/18 02:56 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I don't have many "good" pictures, just some sporadic in-process ones. I kept the torsion bars on my car, so I needed some good structure there. My torsion bar crossmember has the new upper support and what stock crossmember that was left was boxed. I added a new fore/aft frame member as well to help scatter some t-bar load toward the front.
Mine is a T56 Magnum, similar enough to the TR6060 you are probably playing with.
11201822_1017343168309741_7346252927187080633_n.jpg11888021_1023578791019512_4088883210097115333_n.jpg13331151_1198169900227066_6468572812618792965_n-2.jpg
2020 RAM 1500
Re: 1970 cuda / 6.4 hemi with a 6 speed manual HELP!!!! [Re: GRAYBO] #2441203
01/26/18 09:40 PM
01/26/18 09:40 PM
S.E. Missouri
AeroMonte Offline
AeroMonte  Offline
S.E. Missouri
I emailed you some pics today also. I went with an aftermarket k member and coil over shocks. Deleted the torsion bars so I don't have the same rigidity issues that Goody has. I am adding sub frame connectors from US Car Tool though.
Re: 1970 cuda / 6.4 hemi with a 6 speed manual HELP!!!! [Re: GRAYBO] #2450773
02/12/18 05:59 PM
02/12/18 05:59 PM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
I raised the tunnel 1" in a 70 Road Runner for a Gen2 Hemi and a Magnum 6 Spd.
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
Re: 1970 cuda / 6.4 hemi with a 6 speed manual HELP!!!! [Re: GRAYBO] #2450844
02/12/18 07:58 PM
02/12/18 07:58 PM
Canada
onig Offline
onig  Offline
Canada
I like your homemade rotisserie.
69 Dart
Re: 1970 cuda / 6.4 hemi with a 6 speed manual HELP!!!! [Re: GRAYBO] #2451035
02/13/18 12:40 AM
02/13/18 12:40 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
looks like you can bolt the rotisserie back together and have the family over for thanksgiving.....
Re: 1970 cuda / 6.4 hemi with a 6 speed manual HELP!!!! [Re: savoy64] #2451078
02/13/18 02:42 AM
02/13/18 02:42 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
It now serves as a ramp to my shed. laugh2
2020 RAM 1500
