I used pui I believe on a similar set... the fronts were great, the backs were horrible. At least the backs look good on those cover.
I agree with moparnation74... just look at foam for an e-body, rounded to match the contour of the cover. Maybe even rollbar shaped foam, not right density, but has to be rounded foam out there that would work.
