572-13 valve covers #2450451
02/12/18 01:12 AM
02/12/18 01:12 AM
ohio
slomoshun Offline OP
ohio
Besides Indy valve covers what r you using on your 572-13 heads
Re: 572-13 valve covers [Re: slomoshun] #2450474
02/12/18 02:12 AM
02/12/18 02:12 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
You can use pretty much any cover you like but you will need to install spray bars in them unless you are oiling the pushrods.
Todd
Re: 572-13 valve covers [Re: slomoshun] #2450651
02/12/18 01:46 PM
02/12/18 01:46 PM
Penna
70satelliteguy Offline
Penna
We installed spray bars in our valve covers. Has worked well now for the past 8 years. Also make sure your rocker arms clear the valve cover or you will have to modify them .
Mike
Re: 572-13 valve covers [Re: slomoshun] #2451538
02/14/18 02:12 AM
02/14/18 02:12 AM
montana
BANDIT Offline
BANDIT  Offline
montana
I am using the 440source fabbed ones, just had to narrow down the top rail to clear pushrods, way cheaper than some and they have sealed well for 2 seasons. Jim
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
