Torsion Bars or Coil Overs?
#2449721
02/10/18 08:03 PM
02/10/18 08:03 PM
Posts: 732 eastern,Ky
70RT Charger
eastern,Ky
I’ve been thinking seriously about biting the bullet on a new Coil Over set up. Well I thought maybe I need to start doing some research first. Now I don’t do autocross or Racing. Just want a good driver. I’m just getting my car back on the road. Now before I start I do have a new Borgeson set up, box and pump and new Viking shocks all around. Well As I’m doing my research maybe this coil over set up isn’t what it’s cracked up to be, maybe more a fad than anything. I see some good points as allowing better header choice and so forth for the guys who need it. Ive read arguments over again and again which one is the best and I personally can’t see the justification or advantages for me going coil over but I’m all ears. I know I am going to need new torsion bars as I have weak one on the passenger side. Any ideas or recommendations? I’ll listen to them. Thanks!!!
Re: Torsion Bars or Coil Overs?
[Re: 70RT Charger]
#2449747
02/10/18 08:55 PM
02/10/18 08:55 PM
Posts: 200 Colorado
Bob J
Colorado
For the money it will be hard to beat Hotchkis and still use your Borgeson box and Viking shocks.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS 68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam 65 Chrysler 300 Convert. project 57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son 2003 Dodge Dakota R/T "DEAD"
[Re: 70RT Charger]
#2449782
02/10/18 09:37 PM
02/10/18 09:37 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
I’ve been thinking seriously about biting the bullet on a new Coil Over set up. Well I thought maybe I need to start doing some research first. Now I don’t do autocross or Racing. Just want a good driver. I’m just getting my car back on the road. Now before I start I do have a new Borgeson set up, box and pump and new Viking shocks all around. Well As I’m doing my research maybe this coil over set up isn’t what it’s cracked up to be, maybe more a fad than anything. I see some good points as allowing better header choice and so forth for the guys who need it. Ive read arguments over again and again which one is the best and I personally can’t see the justification or advantages for me going coil over but I’m all ears. I know I am going to need new torsion bars as I have weak one on the passenger side. Any ideas or recommendations? I’ll listen to them. Thanks!!! Better header clearance....BIG deal! The Dougs and TTI headers fit great with a stock chassis. The cost of the aftermarket coil over setups is a hard pill to swallow as well. A friend installed a Magnum Force kit and ended up with a wider turning radius and less suspension travel...For almost $5000.
[Re: 70RT Charger]
#2449874
02/11/18 12:10 AM
02/11/18 12:10 AM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
If you are starting with a car that the front stock front end needs everything rebuilt I would do a coil over conversion.... just my opinion.
A new iron curtain drawn across the 49th parallel
[Re: 70RT Charger]
#2449943
02/11/18 03:30 AM
02/11/18 03:30 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Now I don’t do autocross or Racing. Just want a good driver. Said it all right there, you want a good torsion bar setup with better tires. "Coilovers" don't just magically equal better handling. They can be made to handle worse, if put into the wrong hands.
[Re: 70RT Charger]
#2450016
02/11/18 12:58 PM
02/11/18 12:58 PM
67autocross
Manitoba Canada
Everything is brand new in the front end, all of it. I’ve also read several times about people actually being disappointed with the coil over set up after they made the switch. If you have everything new I would stick with the factory front end, you would be wasting money if that’s important to you.
[Re: 70RT Charger]
#2450054
02/11/18 02:09 PM
02/11/18 02:09 PM
67autocross
Manitoba Canada
Well I would go with all the usual stuff like big torsion bars, adjustable A arms and a sway bar. PST has a lot of good products that are well priced... one place I would spend money on is shocks. I have Vikings on a few cars and really like adjustable compression and rebound ability, although I feel they could be valved a bit softer.
[Re: 70RT Charger]
#2450107
02/11/18 03:24 PM
02/11/18 03:24 PM
Posts: 5,385 Pikes Peak Country
TC@HP2
Pikes Peak Country
There are a few advantages of a coil over system compared to most stock systems. Typically, they are compact and lightweight. They also offer a broad ranges of spring rates from very light to super heavy and are separated by only 50# increments. They allow fast spring changes and easily adjustable ride heights.
So, if you need a lightweight systems with access to multiple rates that allow quick changes, then a coil over system is for you.
If you prefer a set it and forget it approach for something that allows you to have fun driving your vehicle, then you most likely only need to step up the rates slightly, improve your alignment specs, and get better tires.
Hotchkis and Firm feel can offer you stock based systems that can be incrementally upgraded over time, or all purchased at once for a complete make over. A call to discuss either approach and specific items recommended would be time well spent.
The shotgun approach is simply 1" t-bars, 1.125" front sway bar, XHD or equivilent leaf springs, better shock control, 2005 Mustang GT alignment specs, and 200 treadwear tires.
[Re: TC@HP2]
#2450110
02/11/18 03:31 PM
02/11/18 03:31 PM
70RT Charger
eastern,Ky
The shotgun approach is simply 1" t-bars, 1.125" front sway bar, XHD or equivilent leaf springs, better shock control, 2005 Mustang GT alignment specs, and 200 treadwear tires. That sounds reasonable enough. Just deciding which brand of parts seems the battle but I do love the Qa1 lower tubular control arms and I can get them at Mancinis for a descent price
[Re: 70RT Charger]
#2450113
02/11/18 03:34 PM
02/11/18 03:34 PM
Posts: 27,444 So Cal
autoxcuda
So Cal
The shotgun approach is simply 1" t-bars, 1.125" front sway bar, XHD or equivilent leaf springs, better shock control, 2005 Mustang GT alignment specs, and 200 treadwear tires. That sounds reasonable enough. Just deciding which brand of parts seems the battle but I do love the Qa1 lower tubular control arms and I can get them at Mancinis for a descent price The tubular upper and lowers will not change any seat of the pants feel on a street cruiser setup like yours. Purely for looks. The basic setup "shotgun approach" highlighted above with your borgenson box should work fine. Bilstein RCD shocks should be sufficient too. You might get some added precision steering/driving feel with a firm feel roller bearing idler arm conversion and steering support. Moog offest rubber upper control arm bushings should help you get the alignment right. I'd go with rubber lower bushings too for a street cruiser.
[Re: 70RT Charger]
#2450358
02/11/18 11:01 PM
02/11/18 11:01 PM
autoxcuda
So Cal
I know the Qa1 uppers have 3 degrees of extra caster built into them. I do have the offset Moog bushings already in my upper A arms. I don’t know what billstein RCD shocks are or the lower rubber bushings but I have a brand new set of Vikings on it. I plan on Running Nittos on it. I bought my rear springs several years ago before I knew about any of this upgraded stuff. I believe they were HD Mopar Performance springs just like it would have on it brand new but I would like to lower it 2” without buying new springs if that’s possible. Thanks for all the help and suggestions guys, it’s much appreciated. What tire sizes are those. Speed rated performance tires? Those Viking shock are fine. Better than the RCD's most likely. Offset bushing in the upper a-arm are fine. I meant rubber lower control arm bushings in your stock lower control arms.
