Dry Sump Oil Tank mounting question... 40Ford?????? #244924
03/06/09 01:59 PM
03/06/09 01:59 PM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
I was talking to one of the local circle track guys here and he told me the return line has to empty into the tank higher than the engine He didn't know why thats just what he was told. Can anyone explain this to me.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Dry Sump Oil Tank mounting question... 40Ford?????? [Re: DemonDust] #244925
03/06/09 05:43 PM
03/06/09 05:43 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
I have never heard that! I would just make sure Its higher than the pump!
Re: Dry Sump Oil Tank mounting question... 40Ford?????? [Re: boatracer572] #244926
03/06/09 06:42 PM
03/06/09 06:42 PM
Menomonee Falls
Menomonee Falls
Thats what I thought too.. Being higher than the engine makes no sense to me
SDG Motorsports
Re: Dry Sump Oil Tank mounting question... 40Ford?????? [Re: DemonDust] #244927
03/06/09 11:58 PM
03/06/09 11:58 PM
Shelbyville, TN USA
40ford Offline
mopar addict
40ford  Offline
mopar addict
Shelbyville, TN USA
Don't worry about getting the tank higher than the engine---just worry about the oil level in the tank being higher than the pump!
A pump can(and does) lose its "prime"! So to keep the pump primed all the time, you mount the tank so the oil level is always above the pump.
Now for a true story---A friend had a nice dry sump installation----worked fine! This is until he put the car on an inclined trailer and pulled about 200 miles. Fried the engine on startup! Why? The pump was above the tank for the 200 mile trip and the pump would not suck oil on startup!
Opps!
Re: Dry Sump Oil Tank mounting question... 40Ford?????? [Re: 40ford] #244928
03/07/09 09:59 AM
03/07/09 09:59 AM
Menomonee Falls
Menomonee Falls
The bottom of the tank will be will easily be above the pump.
Thanks for the info. If I had to mount it the other way I have no idea where I'd mount it.
SDG Motorsports
Re: Dry Sump Oil Tank mounting question... 40Ford?????? [Re: DemonDust] #244929
03/07/09 10:45 AM
03/07/09 10:45 AM
Oklahoma
silverfish Offline
silverfish  Offline
Oklahoma
I'm new to this dry sump thing too. I was told that you have to prime the pump any time the motor sits for a 12 hour or more time period. They told me the reason for this is because gravity drains all the oil out of the tank while it sits. Peterson told me you have to be able to slip the belt off the pulley and spin it with a drill or something until you see oil pressure start to build. They say after that you're good for that day. Like I said I'm new to this and haven't even fired the engine up yet so I'm just relaying what I was told. Anyway, here is a pic of how I mounted mine...
Re: Dry Sump Oil Tank mounting question... 40Ford?????? [Re: silverfish] #244930
03/07/09 11:27 AM
03/07/09 11:27 AM
Shelbyville, TN USA
40ford Offline
mopar addict
40ford  Offline
mopar addict
Shelbyville, TN USA
Under normal conditions---you do not need to reprime the pump before startup. If we haven't started the engine for a week, we might spin the engine over for 15 seconds before turning on the ignition. If we haven't started the engine for 1 month, we probably would reprime.
Think about a dry sump system as two separate systems, the pressure system and the scavenge system. The scavenge system goes from the oil pan to the pump and into the top of the tank. There is no way for the oil to get from the tank back into the oil pan if it is plumbed correctly. The tank keeps the pressure section always primed---and there is no way that gravity can drain a tank UNLESS the tank is mounted well above the engine.
Re: Dry Sump Oil Tank mounting question... 40Ford?????? [Re: 40ford] #244931
03/07/09 11:41 AM
03/07/09 11:41 AM
Oklahoma
silverfish Offline
silverfish  Offline
Oklahoma
Thanks! I was wondering about just spinning the engine over like you say. Thats basically the same as spinning it over with a drill. Also, I'm glad you confirmed the drain back thing too. I thought the exact same thing when I was told the oil would run back into the pan. The only line coming out of the bottom of the tank is the suction line that goes to the pump. Thanks for the clarification.
Re: Dry Sump Oil Tank mounting question... 40Ford?????? [Re: 40ford] #244932
03/07/09 11:58 AM
03/07/09 11:58 AM
Menomonee Falls
Menomonee Falls
Great! Thanks for the all the info. I didn't want to burn anything up either. Pretty simple.
I was wondering about turning the engine over with the ign off to prime it, if it sits for a while.
Thanks again
SDG Motorsports
Re: Dry Sump Oil Tank mounting question... 40Ford?????? [Re: silverfish] #244933
03/07/09 11:59 AM
03/07/09 11:59 AM
San Jose Ca.
San Jose Ca.
Peterson Fluid systems make nice drive nuts for the pump pulley to prime!I can remove the belt
on the pump,and spin the pump by "hand" and see 40 psi!!
Re: Dry Sump Oil Tank mounting question... 40Ford?????? [Re: silverfish] #244934
03/07/09 12:04 PM
03/07/09 12:04 PM
Menomonee Falls
Menomonee Falls
One more dumb question, can these pumps cavitate and lose their prime if there isn't any oil for them to pickup for a short time? Say on accel or decel?
Just curious, cause my block has a scavenge in the rear of the cam tunnel, but the cam tunnel has some holes drilled in it to drain to the oil pan. Should I run the pickup in the rear or just cap it off? Cause it may be just sucking air %80 of the time
SDG Motorsports
Re: Dry Sump Oil Tank mounting question... 40Ford?????? [Re: DemonDust] #244935
03/07/09 03:50 PM
03/07/09 03:50 PM
Shelbyville, TN USA
40ford Offline
mopar addict
40ford  Offline
mopar addict
Shelbyville, TN USA
Without knowing your block exactly, I would say run the rear pickup. All the scavenge sections run dry some---think about it, one pressure section, three or four scavenge sections. They actually suck air most of the time---that's what builds the great vacuum in the engine!
Re: Dry Sump Oil Tank mounting question... 40Ford?????? [Re: DemonDust] #244936
03/07/09 07:27 PM
03/07/09 07:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
As 40 said they do run some oil all the time but you
have 2,3, or even 4 times the scavenge rate of the
supply side... also this is the reason the dry sump
creates a vac in the engine. With just the dry sump
on my engine it creates 12" of hg in the higher revs
Re: Dry Sump Oil Tank mounting question... 40Ford?????? [Re: MR_P_BODY] #244937
03/08/09 02:09 AM
03/08/09 02:09 AM
Menomonee Falls
Menomonee Falls
Wow that's more vaccum than some street engines. Sorry for the dumb questions I just want to cover all my bases. So I don't screw anything up.
Thanks for taking the time to explain this to me. I've always stuck to my stock SB oil systems so the whole dry sump is new to me.
SDG Motorsports
