TTI header sensor bung location
#2449276
02/09/18 10:01 PM
02/09/18 10:01 PM
Posts: 4,974 new jersey usa
11secdart
new jersey usa
I just got my new set of TTI headers for my 408 and paid extra to have the sensor bungs installed. They put the sensor bungs on the outside of the collector is this were they put them? I don`t like it, I would rather have them on the inside out of sight. The dealer I purchased them thru is looking into it on Monday. Anybody have their headers with the bungs installed, were are yours?
Re: TTI header sensor bung location
[Re: 11secdart]
#2449286
02/09/18 10:24 PM
02/09/18 10:24 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Outside helps keep the route away from the heat.Easier to take out when not in use.
[Re: hemi-itis]
#2449291
02/09/18 10:33 PM
02/09/18 10:33 PM
11secdart
new jersey usa
I guess i just assumed they would be on the inside, It does`t say inside or outside in the catalog but the picture has them on the outside. I guess I should have requested inside not assumed they would be. I don`t want them with the sensor outside I hope I can return them, I just opened the box today the headers are still in the bags.
[Re: Mr D21]
#2449296
02/09/18 10:45 PM
02/09/18 10:45 PM
11secdart
new jersey usa
Good point I never even thought about that when I read it now or before i ordered them. I guess there will be a brand new set of TTi headers for sale on Moparts soon.
[Re: 11secdart]
#2449339
02/10/18 12:22 AM
02/10/18 12:22 AM
Posts: 8,018 Tulsa OK
Bad340fish
Tulsa OK
Are you sure there is even room on the inside? Mine are not in the headers but just a few inches back from the collector in the exhaust. I don't think there is room to point the 02s towards the transmission.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2449353
02/10/18 12:47 AM
02/10/18 12:47 AM
11secdart
new jersey usa
There should be , my old Tubular Automotive headers had them in the collectors and had plenty of room. I am thinking if I can`t return them I will just put plugs in the bungs and only screw the sensor in if I am test and tuning or want a reading
[Re: 11secdart]
#2449395
02/10/18 02:55 AM
02/10/18 02:55 AM
Posts: 4,269 Morrow, OH
markz528
Morrow, OH
My sensor instructions says that the sensor must be angled. 9 and 3 o’click don’t work for that.
[Re: markz528]
#2449441
02/10/18 11:31 AM
02/10/18 11:31 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
My sensor instructions says that the sensor must be angled. 9 and 3 o’click don’t work for that. It helps with condensation staying off of the sensor. My Innovate wideband works fine at 3 o'clock.
[Re: 11secdart]
#2449515
02/10/18 02:20 PM
02/10/18 02:20 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
You can simply plug the outside sensor bung and weld a new one on the inside where you want it.
The only potential issue would be the TTI ceramic coating will get nerfed around the newly welded bung. I've touched my silver ceramic coating up virtually invisibly with High temp BBQ paint.
I've since painted my entire exhaust system black with VHT High Temp paint. The ceramic coating from TTI is great as a substrate for high temp paint. VHT's High Temp paint is amazing stuff, it holds up well and you can touch it up any time you want.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: 11secdart]
#2449550
02/10/18 03:23 PM
02/10/18 03:23 PM
Posts: 4,707 Star Idaho
67vertman
Star Idaho
On my 1970 Cuda, the bung is at the 3:00 position. Been there for five years and no problems, and as Mike said it cannot be seen unless your under the car. Also having it on that side keeps wiring from being run over or under the header.
My Monster are real!
Living within your means makes life pretty easy.
[Re: Cab_Burge]
#2450044
02/11/18 02:01 PM
02/11/18 02:01 PM
11secdart
new jersey usa
Update: I decided to keep them and am about half way thru the installation, definitely not easy. My old Tubular Automotive headers came apart for installation which was much easier, but then again were they slipped together was starting to wear and leak.
[Re: 11secdart]
#2450560
02/12/18 09:29 AM
02/12/18 09:29 AM
11secdart
new jersey usa
In and almost done... have to solve a clearance problem as the drivers side collector is hitting my shifter cable hold down, collectors are really close to the trans pan. I would have preferred to have them sit a little lower. Passenger side was a lot easier to install than the drivers side. I also wish the bolt holes on the head side flanges were a little larger other than that they seem ok. I now see why the bung holes are in the outside not really much room on the inside.
