#2449276 - 02/09/18 07:01 PM TTI header sensor bung location
11secdart Offline
Loc: new jersey usa
I just got my new set of TTI headers for my 408 and paid extra to have the sensor bungs installed. They put the sensor bungs on the outside of the collector is this were they put them? I don`t like it, I would rather have them on the inside out of sight. The dealer I purchased them thru is looking into it on Monday. Anybody have their headers with the bungs installed, were are yours?
08 1500 Quad Cab Hemi 4x4
92 D150 5.2 (318) 2WD,shortbed,original owner, multiple time Trophy Class Winner @ Mopar Meets
68 Dart 408 ci, R3, Indy Heads, pump gas, 904, 3,150 lbs, footbrake, mid 11's
2013 Island Dragway Street Eliminator Points Champion
2014 Raceway Park ( R.I.P. 2018 ) 11.50 Index Points Champion
#2449282 - 02/09/18 07:15 PM Re: TTI header sensor bung location [Re: 11secdart]
Mr D21 Offline
Loc: california
Straight from their website - no additional investigation needed...
http://www.ttiexhaust.com/MoparClassics-Headers/340-Step/TTi340.htm#options
70 Chall - FC7, V1X, D21, E86
70 GTX - FE5, V1X, N96, E87
#2449286 - 02/09/18 07:24 PM Re: TTI header sensor bung location [Re: 11secdart]
hemi-itis Offline
Loc: Great Neck,LI,new york
Outside helps keep the route away from the heat.Easier to take out when not in use.
HEMI-ITIS has no cure. My condition is fully BLOWN!!!
New best 60ft,, 1.42,1/8, 6.0 @117,, 9.38 @146.75 with 6 lbs boost @3700 lbs
#2449291 - 02/09/18 07:33 PM Re: TTI header sensor bung location [Re: hemi-itis]
11secdart Offline
Loc: new jersey usa
I guess i just assumed they would be on the inside, It does`t say inside or outside in the catalog but the picture has them on the outside. I guess I should have requested inside not assumed they would be. I don`t want them with the sensor outside I hope I can return them, I just opened the box today the headers are still in the bags.
#2449293 - 02/09/18 07:38 PM Re: TTI header sensor bung location [Re: 11secdart]
Mr D21 Offline
Loc: california
This is from their webpage... so not sure what they are willing to do as it's clear here:
Installation locations: Drivers-side, 9 o'clock / Passenger-side, 3 o'clock
#2449296 - 02/09/18 07:45 PM Re: TTI header sensor bung location [Re: Mr D21]
11secdart Offline
Loc: new jersey usa
Good point I never even thought about that when I read it now or before i ordered them. I guess there will be a brand new set of TTi headers for sale on Moparts soon.
Edited by 11secdart (02/09/18 07:47 PM)
#2449339 - 02/09/18 09:22 PM Re: TTI header sensor bung location [Re: 11secdart]
Bad340fish Offline
Loc: Tulsa OK
Are you sure there is even room on the inside? Mine are not in the headers but just a few inches back from the collector in the exhaust. I don't think there is room to point the 02s towards the transmission.
68 Barracuda Formula S 340
#2449353 - 02/09/18 09:47 PM Re: TTI header sensor bung location [Re: Bad340fish]
11secdart Offline
Loc: new jersey usa
There should be , my old Tubular Automotive headers had them in the collectors and had plenty of room. I am thinking if I can`t return them I will just put plugs in the bungs and only screw the sensor in if I am test and tuning or want a reading
#2449360 - 02/09/18 09:58 PM Re: TTI header sensor bung location [Re: 11secdart]
GoodysGotaCuda Online   penguin-006
5.7L Hemi, 6spd
Loc: Texas
My TTI bunks are toward the outside. Can't be seen in my 'Cuda, though, unless you're under it.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
1976 Dodge Warlock - "Her Truck" - 360/727 2wd
2016 Subaru WRX - E30 Tune ~320whp
#2449395 - 02/09/18 11:55 PM Re: TTI header sensor bung location [Re: 11secdart]
markz528 Offline
Loc: Milford, OH
My sensor instructions says that the sensor must be angled. 9 and 3 o’click don’t work for that.
67 Coronet 500 (street car) 13.300 @ 101.75 mph
#2449441 - 02/10/18 08:31 AM Re: TTI header sensor bung location [Re: markz528]
5.7L Hemi, 6spd
Loc: Texas
It helps with condensation staying off of the sensor. My Innovate wideband works fine at 3 o'clock.
#2449515 - 02/10/18 11:20 AM Re: TTI header sensor bung location [Re: 11secdart]
jbc426 Offline
Loc: West Coast, USA
You can simply plug the outside sensor bung and weld a new one on the inside where you want it.
The only potential issue would be the TTI ceramic coating will get nerfed around the newly welded bung. I've touched my silver ceramic coating up virtually invisibly with High temp BBQ paint.
I've since painted my entire exhaust system black with VHT High Temp paint. The ceramic coating from TTI is great as a substrate for high temp paint. VHT's High Temp paint is amazing stuff, it holds up well and you can touch it up any time you want.
1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 3.91's (closest thing to an automatic 5 speed going)
#2449544 - 02/10/18 12:09 PM Re: TTI header sensor bung location [Re: 11secdart]
Thumperdart Offline
Loc: State of confusion
I think they need to be in the exhaust NOT in the header that way you read the "averages" better and that's also what my instructions said........... coffee
#2449550 - 02/10/18 12:23 PM Re: TTI header sensor bung location [Re: 11secdart]
67vertman Offline
Loc: California USA
On my 1970 Cuda, the bung is at the 3:00 position. Been there for five years and no problems, and as Mike said it cannot be seen unless your under the car. Also having it on that side keeps wiring from being run over or under the header.
#2449860 - 02/10/18 08:43 PM Re: TTI header sensor bung location [Re: 11secdart]
'68cuda416 Offline
Loc: kansas city missouri united st...
I use thier headers and had the bungs welded into thier collectors with both sides pointing towards the transmission, car is a ‘68 barracuda. For what it’s worth I only run 1 sensor but if I wanted to I could put it in either side.
#2449941 - 02/11/18 12:17 AM Re: TTI header sensor bung location [Re: '68cuda416]
Loc: Bend,OR USA
I think all the instructions I've read or heard about of say to NOT mount them from 3:00 down and around to 9:00 o clock, from 9:00 up to and back down to 3:00 O clock is the proper way for clocking the bungs so condensation won't form on the tips of the sensors shruggy
#2450044 - 02/11/18 11:01 AM Re: TTI header sensor bung location [Re: Cab_Burge]
11secdart Offline
Loc: new jersey usa
Update: I decided to keep them and am about half way thru the installation, definitely not easy. My old Tubular Automotive headers came apart for installation which was much easier, but then again were they slipped together was starting to wear and leak.
#2450560 - 02/12/18 06:29 AM Re: TTI header sensor bung location [Re: 11secdart]
11secdart Offline
Loc: new jersey usa
In and almost done... have to solve a clearance problem as the drivers side collector is hitting my shifter cable hold down, collectors are really close to the trans pan. I would have preferred to have them sit a little lower. Passenger side was a lot easier to install than the drivers side. I also wish the bolt holes on the head side flanges were a little larger other than that they seem ok. I now see why the bung holes are in the outside not really much room on the inside.
#2451571 - 02/14/18 03:44 AM Re: TTI header sensor bung location [Re: 11secdart]
crash520 Offline
Loc: Brisbane Australia
Mine are on the outside, I don’t like that they can’t figure out to angle them up slightly, my drivers side is pretty much horizontal, my passenger side is angled down, this is against all makers direction that the sensor should have a slightly downward angle at the sensor when installed, my TTI’ are coated and polished which makes it difficult now to rectify
25,742 Registered Members
192,975 Topics
USA source for German made tools
by 360view
02/20/19 03:42 PM
I like trains
by bigdad
02/20/19 03:17 PM
Fiddy Three Dodge w/ Hemi
by Neil
02/20/19 03:02 PM
(2) 66 Chargers
by Neil
02/20/19 03:01 PM
