#2449009 - 02/09/18 03:17 AM 1965 727 tail shaft housing - '65 ONLY?
6bblgt Offline
Loc: Las Vegas, NV
is the slip joint tail shaft housing for a '65 727 one year only?
- Dan
#2449016 - 02/09/18 06:04 AM Re: 1965 727 tail shaft housing - '65 ONLY? [Re: 6bblgt]
Transman Offline
Loc: Michigan
Yes
#2449076 - 02/09/18 10:17 AM Re: 1965 727 tail shaft housing - '65 ONLY? [Re: 6bblgt]
dvw Offline
Loc: MI, usa
So is the output shaft. However small block 65 parts from 65 318 poly motor 727 can be used to upgrade BB earlier ball and trunion style 727.
Doug
#2449118 - 02/09/18 12:23 PM Re: 1965 727 tail shaft housing - '65 ONLY? [Re: dvw]
Loc: Bend,OR USA
Doug
iagree
Done many times by many people up
#2449149 - 02/09/18 01:43 PM Re: 1965 727 tail shaft housing - '65 ONLY? [Re: dvw]
Morty426 Offline
Loc: Sacramento CA
Doug
That's good to know up
#2449210 - 02/09/18 04:48 PM Re: 1965 727 tail shaft housing - '65 ONLY? [Re: dvw]
Part_Stalker Offline
Loc: The Scratch, WA
Doug
Can someone please explain a little more. I have many 65 and earlier cars and trans but have never bothered to save many of the 65 SB trans. Is it just the input and output shafts or something more?
#2449218 - 02/09/18 04:57 PM Re: 1965 727 tail shaft housing - '65 ONLY? [Re: 6bblgt]
Transman Offline
Loc: Michigan
Save the whole output shaft and extension housing assemblies off those small block 1965 727's. Keep the park mechanism intact and I would save all the cables unless they are toast.
Console shift valve bodies differ from push button so I would save those as well.
Most guys get rid of the early input shaft and reaction shaft and replace them with 1967 and later stuff as the spline count changed between early and late.
Actually if you have the room - just keep the whole trans - everything can be transferred to a big block case.
You never know when you may need something.
Remember - there is no such thing as a poor junkman.
Edited by Transman (02/09/18 05:00 PM)
#2449222 - 02/09/18 05:05 PM Re: 1965 727 tail shaft housing - '65 ONLY? [Re: Transman]
Thanks for the education Transman, I learned something new today. Now I won't have to spend so much time hunting for 65 BB trans I can use some of the 62-64 ones I have around.
#2449241 - 02/09/18 05:46 PM Re: 1965 727 tail shaft housing - '65 ONLY? [Re: dvw]
64Post Offline
Loc: Baltimore/Denver
Doug
That's good to know. Still can't seem to give these things away though.
#2449862 - 02/10/18 08:46 PM Re: 1965 727 tail shaft housing - '65 ONLY? [Re: 6bblgt]
dvw Offline
Loc: MI, usa
I usually upgrade the reaction support (or complete pump) and the input shaft to 67 or newer. This allows current spline converters. If you use 71 and up reaction support and front drum you also get the benefit of the wide bushing drum.
Doug
25,746 Registered Members
193,058 Topics
Lego 1967 Mustang
by DirectSubjection
02/23/19 09:44 PM
Whos selling AMD at Indy??
by Chally426
02/23/19 09:21 PM
Life of drag Slicks ?
by Hemi Allstate
02/23/19 08:24 PM
67 Coronet, Rear Springs, Sway Bars and Shocks.
by Poppinsmoke
02/23/19 06:12 PM
