Page 6 of 9 < 1 2 3 4 5 6 7 8 9 >
#2442309 - 01/28/18 01:44 PM CSR Carbon Fiber Shield [Re: Rocket]
cl440 Offline
Loc: S.E. Michigan
SOLD Used, expired CSR #836 727 Carbon Fiber Shield
Been trimmed in a couple spots for fitment. Pictures tell the story.
$125.00 OBO plus the ride
pm me or chucklewis440@gmail.com
Edited by cl440 (01/29/18 02:13 PM)
#2442311 - 01/28/18 01:49 PM Adjustable Vacuum Secondary [Re: cl440]
cl440 Offline
Loc: S.E. Michigan
SOLD Used very little.
From Summit Racing website:
Housing Cover, Vacuum Secondary Diaphragm, Billet Aluminum, 4160.
Quick Fuel adjustable vacuum secondary kits will allow you to adjust the vacuum secondary by simply turning the screw to change the rate of opening. They feature a billet aluminum cover with integrated adjustment screw and feature a polished finish.
$25.00 plus the ride
Edited by cl440 (01/30/18 03:51 PM)
#2442442 - 01/28/18 06:03 PM Re: Adjustable Vacuum Secondary [Re: cl440]
dsd70bee Offline
Loc: oak park, il.
Very rare 1971 340 SIX PACK set up off of a Mr. Norms Grand Spaulding Dodge GSS Demon $2500.00 (708)288-2879 Scott
#2442467 - 01/28/18 06:31 PM Re: For Sale - Race Parts - 1st Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
One pair of 1968 426 HEMI Super Stock Holley crossram carbs, List 4235 and 4236 in excellent used condition, very little run time $1150.00 for the pair (708)288-2879 Scott
#2442500 - 01/28/18 07:12 PM Re: For Sale - Race Parts - 1st Quarter [Re: moparts]
68shifter Offline
Loc: MI
Strange Dana 60 housing.
44" Axle/Axle
5.13 Richmond pro gear. Strange spool. Strange 35 spline star flange axles. 1350 Moly yolk. Has 4 link brackets etc but can be removed. Aluminum LPW cover.
Should have new bearings.
1200 obo. Thanks Moparts.
#2442512 - 01/28/18 07:36 PM Re: For Sale - Race Parts - 1st Quarter [Re: 68shifter]
dsd70bee Offline
Loc: oak park, il.
One set of 426 HEMI rocker assemblies, Everything aftermarket for a Top Fuel or Alcohol aluminum type head, Stage V roller tip intake rockers $2000.00 for the pair (708)288-2879 Scott
#2442544 - 01/28/18 08:36 PM Re: For Sale - Race Parts - 1st Quarter [Re: dsd70bee]
earthmover Offline
Loc: nc
Plastic race seat no cover 25.00
Oberg oil filter 125.00
Lunati solid roller cam 250.00 big block
Cam motion solid roller cam 250.00 big block
440source timing set double roller with bearing on it 50.00 big block
J e dome tops piston out my 451 low deck 250.00
Eagle hbeams rods out the 451 low deck 175.00 1 got hot but no spun bearings at all
Indy big block valve covers 150.00
New summit cam sum 6401 part number had. Big block 50.00
8 3/4 big bolt axles long race studs good bearing 200.00
Big block aluminium fab valve covers 75.00
Flex plate new 30.00
W2 intake gasket new in pack 20.00
A body radiator out my 70 duster 50.00
A body washer res. With pump 30.00
Rb push rods out of 528 100.00
Low deck push rods out my 451 almost new 100.00
earthmover
in the tire smoke
Lunati cam specs
280@50
457 love life
457 love life
With 1.5 686 lift
26 last hot
108 they recommend 4 advance
Cam motion
108 ing. Centerline
112 lobe separation
@50. 273 ing. Due.
283 ex due.
461 lobe lift intake
441 lobe lift ex.
24 hot
Edited by earthmover (01/30/18 02:35 PM)
#2442634 - 01/28/18 10:34 PM Re: For Sale - Race Parts - 1st Quarter [Re: earthmover]
dsd70bee Offline
Loc: oak park, il.
426 HEMI single 4 BBL. intake manifold taken off a crate HEMI, excellent condition. $375.00 (708)288-2879 Scott
#2442641 - 01/28/18 10:40 PM Re: For Sale - Race Parts - 1st Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
Milodon big block Mopar and 426 HEMI 10 Quart oil pan for AFX or Gasser type car, bolted to an engine for mock up, never ran $400.00 (708)288-2879 Scott
#2442649 - 01/28/18 10:48 PM Re: For Sale - Race Parts - 1st Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
One pair of used Motor Wheel Fly plastic center caps, as you can see in the pictures one of the center caps is cracked and needs to be repaired, these are very rare and hard to find $100.00 for the pair (708)288-2879 Scott
#2442651 - 01/28/18 10:51 PM Re: For Sale - Race Parts - 1st Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
One pair of vintage M&H front runner drag type tires from the 1960's 5.60-15 $500.00 for the pair (708)288-2879 Scott
#2443197 - 01/29/18 11:05 PM SB 727 and Dynamic 8” converter [Re: moparts]
417_Stroker Offline
Loc: KS
Selling the SB 727 out of my Dart. It was in the car when I bought it and supposedly rebuilt prior to me buying the car. Valve body is a Cheetah 17680. I had a custom 8” converter built by Dynamic Converters that is stalled at 5500 rpm (roughly 500 RWHP 340 3300 lbs with me). I have put about 1200 miles on the car since I’ve owned it. Never had any temp issues. 190 degrees was the highest oil temp I saw even on 100 degree days in stop and go traffic and highway driving. When I took it to the track last fall, it went 10.40’s @ 128 mph with a 1.48 60’ and didn’t feel any problems with the transmission or converter. Selling with or without cast aluminum deep pan.
Trans $500
Converter $500 ($900 new)
TCI pan $100
Or
$1000 for all 3
I also will have the Hughes SFI flex plate, B&M ratchet shifter, and driveshaft available that went with all this. Located in Wichita.
'69 Dart 417 street/strip 10.73@126
#2443224 - 01/30/18 12:14 AM Re: For Sale - Race Parts - 1st Quarter [Re: moparts]
Moparguy383 Offline
Loc: Cumberland, MD
SOLDNew Derale transmission cooler. Part number 13751, 9x9x1.25 inches, -6 AN inlet & outlet. Would not fit my application and I waited to long to return it. My loss is your gain. $50 plus shipping. I will take Paypal if it is sent as a gift.
Email me moparguy383@hotmail.com for more pictures or information.
Edited by Moparguy383 (02/01/18 01:06 AM)
#2443227 - 01/30/18 12:18 AM Re: For Sale - Race Parts - 1st Quarter [Re: moparts]
Moparguy383 Offline
Loc: Cumberland, MD
Pair of new Doug's headers reducers. They are 3.5 inch down to 2.5 inch. 3/8 collector flange. Mounting hardware and gaskets included. $30 plus shipping. I will take Paypal if it is sent as a gift.
#2443229 - 01/30/18 12:20 AM Re: For Sale - Race Parts - 1st Quarter [Re: Moparguy383]
Moparguy383 Offline
Loc: Cumberland, MD
Edelbrock TM7 intake manifold. Has had some smoothing and shaping of the runners. $150 plus shipping. I will take Paypal if it is sent as a gift.
No low ballers or tire kickers!
Email me moparguy383@hotmail.com for more information or pictures
Edited by Moparguy383 (02/10/18 08:36 PM)
#2443230 - 01/30/18 12:22 AM Re: For Sale - Race Parts - 1st Quarter [Re: Moparguy383]
Moparguy383 Offline
Loc: Cumberland, MD
Pair of nice older headers for a big block, they have a few dings and clearance dents but otherwise very nice. They are not rusted out, thin junk. These are well made headers, 2 inch primaries, 3.5 inch collectors. I bought these off of a buddy in 1991 and they have been stored in my climate controlled shop ever since. I had them sand blasted and coated with Eastwood's silver high temperature coating. They would be on my car now, but I found out they will not work with power steering. $225 (FIRM) plus shipping. I will take Paypal if it is sent as a gift.
Edited by Moparguy383 (02/10/18 08:35 PM)
#2443238 - 01/30/18 12:39 AM Re: For Sale - Race Parts - 1st Quarter [Re: Moparguy383]
dsd70bee Offline
Loc: oak park, il.
Vintage Donovan gear drive for big block Mopar and 426 HEMI, I do not have the cam gear or the crank gear, what you see in the pictures is what I have $275.00 (708)288-2879 Scott
#2443244 - 01/30/18 12:45 AM Re: For Sale - Race Parts - 1st Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
One set of eight 426 HEMI Stage V roller tip intake rockers in excellent used condition $750.00 for the set (708)288-2879 Scott
#2443248 - 01/30/18 12:53 AM Re: For Sale - Race Parts - 1st Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
One set of 426 HEMI Crossram linkage, Jegs and Summit price $407.97 my price $300.00 (708)288-2879 Scott
#2443250 - 01/30/18 01:01 AM Re: For Sale - Race Parts - 1st Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
Edelbrock 426 HEMI 2X4 inline Rat Roaster intake manifold, this intake manifold has never been bolted to an engine $500. (708)288-2879 Scott
25,142 Registered Members
186,664 Topics
Guess my Dyno numbers
by 10sec440
02/20/18 01:50 AM
Challenger urethane bumpers
by 2002bluert
02/20/18 12:57 AM
Removing Rusty Rods & Pins From Pistons...
by Clair_Davis
02/19/18 11:45 PM
Where to find a phone number without having to pay for it !!
by Stanton
02/19/18 10:40 PM
