#2449139 - 02/09/18 01:25 PM 273 rockers
DusterKid Offline
Loc: Keymar, MD
To change the factory style 273 rocker arms to a adjusting screw and lock nut, what if anything needs to be done to the rocker arm?
#2449148 - 02/09/18 01:41 PM Re: 273 rockers [Re: DusterKid]
poboyengineering Offline
Loc: pennsylvania
Just spot face the area where the nut will rest.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
#2449704 - 02/10/18 04:36 PM Re: 273 rockers [Re: DusterKid]
DusterKid Offline
Loc: Keymar, MD
I'm assuming the spot face is to help the nut sit flush? Does it have to be done on a lathe or could a sanding belt be good enough?
#2449727 - 02/10/18 05:15 PM Re: 273 rockers [Re: DusterKid]
Loc: pennsylvania
I did mine on a mill. I suppose you could do it on a drill press with a center cutting end mill. And yes, it's to give the nut a flat to tighten against.
#2449731 - 02/10/18 05:17 PM Re: 273 rockers [Re: DusterKid]
jwb123 Offline
Loc: Missouri
Where do you buy the replacement adjusters? I got a set of those rockers in my junk.
#2449739 - 02/10/18 05:37 PM Re: 273 rockers [Re: DusterKid]
Loc: pennsylvania
Isky sells them, among others.
#2450498 - 02/11/18 11:40 PM Re: 273 rockers [Re: DusterKid]
cdp Offline
Loc: MO
https://www.pushrods.net
The factory adjusters are a tapered thread. All you have to do is chase them with a good 5/16-18 or 3/8-24 tap (can't remember which) to finish them out.
I've done 1 set already, but haven't spot faced them yet.
#2451733 - 02/14/18 02:37 PM Re: 273 rockers [Re: DusterKid]
therocks Offline
Its Lost
Loc: Niles , Ohio
My old Sig Ersons were interference fit.They finally started backing off after 30 plus years.Bought MP adjusters and they fit perfect.Still running them and adjust maybe once every 2 years.Rocky
Chrysler Firepower
25,708 Registered Members
196,876 Topics
Small Chrome Plating System
by jim6346
01/23/19 02:09 PM
1968 Dart conversion from sedan to hardtop
by maximus
01/23/19 01:15 PM
Tire Diameter Selection
by gzig5
01/23/19 12:08 PM
1971 Dodge 500 truckt i wish it was
by TNos
01/23/19 11:56 AM
