1965 727 tail shaft housing - '65 ONLY? #2449009
02/09/18 06:17 AM
02/09/18 06:17 AM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
is the slip joint tail shaft housing for a '65 727 one year only?
Re: 1965 727 tail shaft housing - '65 ONLY? [Re: 6bblgt] #2449016
02/09/18 09:04 AM
02/09/18 09:04 AM
A727Tflite Offline
A727Tflite  Offline
Yes
Re: 1965 727 tail shaft housing - '65 ONLY? [Re: 6bblgt] #2449076
02/09/18 01:17 PM
02/09/18 01:17 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
So is the output shaft. However small block 65 parts from 65 318 poly motor 727 can be used to upgrade BB earlier ball and trunion style 727.
Doug
Re: 1965 727 tail shaft housing - '65 ONLY? [Re: dvw] #2449118
02/09/18 03:23 PM
02/09/18 03:23 PM
Doug
iagree
Done many times by many people up
Re: 1965 727 tail shaft housing - '65 ONLY? [Re: dvw] #2449149
02/09/18 04:43 PM
02/09/18 04:43 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Doug
That's good to know up
Re: 1965 727 tail shaft housing - '65 ONLY? [Re: dvw] #2449210
02/09/18 07:48 PM
02/09/18 07:48 PM
The Scratch, WA
P
Part_Stalker Offline
P
The Scratch, WA
Doug
Can someone please explain a little more. I have many 65 and earlier cars and trans but have never bothered to save many of the 65 SB trans. Is it just the input and output shafts or something more?
Re: 1965 727 tail shaft housing - '65 ONLY? [Re: 6bblgt] #2449218
02/09/18 07:57 PM
02/09/18 07:57 PM
A727Tflite Offline
A727Tflite  Offline
Save the whole output shaft and extension housing assemblies off those small block 1965 727's. Keep the park mechanism intact and I would save all the cables unless they are toast.
Console shift valve bodies differ from push button so I would save those as well.
Most guys get rid of the early input shaft and reaction shaft and replace them with 1967 and later stuff as the spline count changed between early and late.
Actually if you have the room - just keep the whole trans - everything can be transferred to a big block case.
You never know when you may need something.
Remember - there is no such thing as a poor junkman.
Re: 1965 727 tail shaft housing - '65 ONLY? [Re: A727Tflite] #2449222
02/09/18 08:05 PM
02/09/18 08:05 PM
The Scratch, WA
P
P
The Scratch, WA
Thanks for the education Transman, I learned something new today. Now I won't have to spend so much time hunting for 65 BB trans I can use some of the 62-64 ones I have around.
Re: 1965 727 tail shaft housing - '65 ONLY? [Re: dvw] #2449241
02/09/18 08:46 PM
02/09/18 08:46 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Doug
That's good to know. Still can't seem to give these things away though.
Re: 1965 727 tail shaft housing - '65 ONLY? [Re: 6bblgt] #2449862
02/10/18 11:46 PM
02/10/18 11:46 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I usually upgrade the reaction support (or complete pump) and the input shaft to 67 or newer. This allows current spline converters. If you use 71 and up reaction support and front drum you also get the benefit of the wide bushing drum.
Doug
