Page 8 of 9 < 1 2 3 4 5 6 7 8 9 >
#2447678 - 02/06/18 07:06 PM turbo action 8” 727 converter [Re: JesseR]
JesseR Online   content
Loc: Mountain City, TN
Like new, only 20 passes, $400 plus shipping
82' dodge pickup with a 499 low deck
#2447725 - 02/06/18 08:05 PM Re: For Sale - Race Parts - 1st Quarter [Re: Dbl"00"Joe]
elephant express Offline
Loc: tampa florida
I have a three circuit 1050 Dominator for 700.00 plus shipping if your interested. Thanks Joe
#2448760 - 02/08/18 07:33 PM Re: A body Aluminum 742 Strange rear end [Re: moparts]
jg309 Offline
Loc: IL. Jerseyville
set w9,13* heads ported,polished,2.15int.,1.64ex.titaum valves,1.70 jessell rockers, pac 1326 springs,retainers,spring cups, valve covers with oilers, mopar m1 intake ported by shady dell intake,heads flow 82/365'4 @.700 exh.88/2768'5@.700, chamber cc 45.02 if u like 2 know anything else call me @ 618-946-2640, $3500, this comes with the head studs, p/s these come off my 362 it made 748hp @ rear wheels
#2449090 - 02/09/18 10:53 AM B1 Heads, Intake, Valves, ARP studs [Re: moparts]
SILVER67 Offline
Loc: Liverpool, NY
B1 Original Heads New
B1 Original
Not the MC
310 cc
Never ported
No valve job as delivered
Require T&D or Jesel rockers
(not included)
New heads
New S/S valves
2.30 / 1.78
ARP B1 stud kit
B1 valve cover’s
B1 intake
No intake spacers
No gaskets
No Rockers
Not drilled for oil return
$3,000
Package Deal ONLY.
NO PAYPAL at all !!
Plus shipping or delivery
Additional photo’s available
dlawd@aol.com
315-657-2808 call/text
Syracuse, NY
Certified check or money order only
NO PAYPAL at all !!
Competition Wedge Engines Brewerton, NY
#2449120 - 02/09/18 12:30 PM 94mm Bullseye BatMoWheel turbo [Re: SILVER67]
fbs63 Offline
Loc: NW Indiana
94mm Bullseye BatMoWheel turbo. Billet compressor wheel, ball bearing, 1.45 AR turbine housing. Like new. 10 passes. Changing to twins. New cost $3600. $1800.00 shipped. Pm here, call or text seven 08-207-five three 74
Edited by fbs63 (02/09/18 12:34 PM)
#2449195 - 02/09/18 04:25 PM Re: 94mm Bullseye BatMoWheel turbo [Re: moparts]
JC Childress Offline
Loc: Big Island ,VA
Solid Roller cam for SB Mopar, LA style engine. This is a custom grind cam from Comp Cams. Its brand new in the box.
INTAKE EXHAUST
Dur @ .050 276 281
Valve Lift .817 .748
Lobe Sep 105
$250.
Call or text me at (434) 665-9541
May trade for parts for 69 Roadrunner
J.C. Childress (434) 665-9541
#2449930 - 02/10/18 11:45 PM Re: For Sale - Race Parts - 1st Quarter [Re: moparts]
TC67CUDA Offline
Loc: Seaside,Ca.
Selling for a friend
426 Hemi 8 New .060 over Pistons 12 to 1 with Rings and wrist pins, Crower Roller Cam Grind #J6489,
16 Valve Springs, 16 Retainers, 16 Keepers, Timing Chain and Gears.
$600.00 for the Whole Package
Call Bob 831-384-6628 Evenings PST
9.94 @ 135
#2450042 - 02/11/18 10:58 AM Re: For Sale - Race Parts - 1st Quarter [Re: moparts]
schmitty Offline
Loc: IN
Greetings - I have a set of eight ARP ss polished Holley carburetor fuel bowl bolts-$14.50. Also complete set of ARP ss polished carburetor stud kit for use with a 1" spacer-$13.50. Both sets are excellent used condition. Plus actual postage. Call 260-223-zero-eight-6-eight up until 8 pm est or schmittyjsathotmaildotcom Thanks Moparts!
Photos: https://flic.kr/p/24fPmr6
Photo: https://flic.kr/p/KiTx7F
#2450064 - 02/11/18 11:17 AM Re: For Sale - Race Parts - 1st Quarter [Re: moparts]
schmitty Offline
Loc: IN
Greetings - I have an excellent used condition 1" Edelbrock phenolic carburetor spacer $19.50 + actual postage. Call 260-223-zero-eight-six-eight or schmittyjsathotmaildotcom Thanks Moparts!
Photo: https://flic.kr/p/XzJ8EY
#2450071 - 02/11/18 11:28 AM Re: For Sale - Race Parts - 1st Quarter [Re: schmitty]
Dragula Offline
Loc: Taxes R-US, NY
SOLD PENDING PAYMENT
440 + .030 Over Super Stock style short block engine f/s
Arias Pistons, High Compression, they only made one piston for Wedge.
Balanced Assy
Eagle Rods H-Beam 7/16 Bolts
New Standard Stroke Crankshaft .010" under
1970 Block with Aluminum Main Caps
Comp Cam & Lifters, Solid Flat Tappet Cam 324A8 .600" Lift 290* duration at 50*
$2500 OBO
Ron Farley 716-799-5588
Edited by Dragula (02/15/18 09:12 PM)
'71 Duster Pump Gas 512RB
https://www.youtube.com/watch?v=Z_XTmRBuvWs (6.19)
https://www.youtube.com/watch?v=gQZGfDBPROM (9.70 at 138.5mph)
'70 Cuda Hemi, 605 almost ready again.
https://www.youtube.com/watch?v=WYw6RA-k5Bk (6.31)
#2450073 - 02/11/18 11:30 AM Re: For Sale - Race Parts - 1st Quarter [Re: Dragula]
Dragula Offline
Loc: Taxes R-US, NY
Turbo Action Convertor for 727
P#17909 8" 5200 stall, like new $400
Edited by Dragula (02/15/18 09:14 PM)
#2450080 - 02/11/18 11:39 AM Re: For Sale - Race Parts - 1st Quarter [Re: Dragula]
Dragula Offline
Loc: Taxes R-US, NY
PAYMENT PENDING
Older Dominator Carb. 1050 3-circuit
Numbers on it:
4-673
12R-4325B
$175
Edited by Dragula (02/13/18 06:27 PM)
#2450188 - 02/11/18 03:13 PM Mopar Performance 8 3/4 Aluminum 742 drop out 4.30 [Re: moparts]
Swingin70 Online   content
Loc: ca
Mopar Perfomance Aluminum 742 case ($1,100 case)
Strange 35 Spline Lightweight Spool
Richmond 4.30 gear set
Strange billet 1350 Yoke
Only 2 Seasons on drop out (70 Passes).
Located in North San Diego
$1600.00
Designed to reduce weight and hold up under high torque. Uses 1-3/4-inch large stem pinion and standard components. The 8-3/4-inch aluminum axle housing uses "742-style" large stem ring and pinions and fits 8-3/4-inch banjo housings (up to 1974). It features a weight reduction of 44% (approximately 11 lbs. to 14 lbs.), compared to production cast iron housing, and includes 6061 billet aluminum caps. It is stiffer than cast iron, and decreases pinion deflection by 10%.
Edited by Swingin70 (02/12/18 01:53 PM)
#2450698 - 02/12/18 12:27 PM Re: For Sale - Race Parts - 1st Quarter [Re: moparts]
dodgedifferent2 Offline
Loc: South western, Ontario
Brand new Icon ic744 SB Chrysler 408, Bore 4.080, Stroke 4.000, Rod Length 6.123, Flat Top -5cc, Set of 8
4 inch stroker .984 floating pin
Compression Ratio with 65cc Heads 11.6:1
Compression Ratio with 70cc Heads 11:1
Advertised piston weight 507 grams, 118 gram wrist pin.
I ordered the wrong pistons and shipping and the restocking fees will be a big loss for me. These are brand new just mocked up one piston to check compression ratio
$514 with free shipping within north america.
#2450817 - 02/12/18 04:19 PM Re: For Sale - Race Parts - 1st Quarter [Re: dodgedifferent2]
Cheatham Offline
Loc: corpus christi tex
A body B1 headers low deck block,original B1 head no torsion bars. From AL Alguire Valiant, Pro Header System built,2 1/8 × 4 in coll. All tunes under chassis, I paid 1100.00, won't fit my application because I have a tall deck with b1s. Maybe AL will answer any questions if I cant. These have been kept indoors since I've had them, very nicely built. Just want my money back, buyer pays shipping. 1100.00. Call or txt 361 876 7793
#2451222 - 02/13/18 12:33 PM 1969 1/2 Six Pack Carbs [Re: Cheatham]
70sixpkRT Offline
Loc: South San Francisco, Ca
I have a set of 1969 1/2 Six Pack carbs for an A12. Front: Date code 1229 part# 4393. Center: Date code 1229 part# 4391 for manual. Rear: Date code 0929 part# 4394. All 3 carbs are untouched and in good condition.
$1600 + shipping + 3% for PayPal.
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
#2451748 - 02/14/18 03:13 PM Re: 1969 1/2 Six Pack Carbs [Re: 70sixpkRT]
evenflow Offline
Loc: illinois
RJS 3" 5 point safety harness punched march 2016. new never used still in package not good for nhra maybe for circle track,demo car, or street machine roll bar mount latch link black in color
part #1125401 (50502-16-06) $40 plus shipping postal money order pm on board or email Aacesandeights@aol.com
Edited by evenflow (Yesterday at 10:44 AM)
#2451997 - 02/14/18 11:33 PM Re: For Sale - Race Parts - 1st Quarter [Re: moparts]
dsd70bee Online   content
Loc: oak park, il.
Max Wedge crossram bell crank NOS never been on a car, not reproduction $125.00 (708)288-2879 Scott
#2452095 - 02/15/18 10:06 AM Re: For Sale - Race Parts - 1st Quarter [Re: moparts]
gtea1901 Offline
Loc: PORT ORANGE FL.
used but in great shape 904 trans 2.74/1.54 gear set with lightened sun shell. $175.00
Call Denny (386) 957-3879 shop (717) 676-3349 cell
stewardperformance.com
#2452111 - 02/15/18 10:49 AM Re: Hoosier 30/10.5R-15 radial drag slicks [Re: moparts]
PHYSIXX Offline
Loc: Edison, New Jersey
I have for sale a pair of used Hoosier 30/10.5R-15 radial drag slicks with the C07 compound and a 92.5 inch circumference. They have about 50% tread left and are in excellent condition. There is some rubbing marks on the inside sidewall of one of the slicks where it rubbed the leaf spring when going around a turn. We took them off because of that and put a set of 9” tires on. I would like to get $125 for the pair plus shipping.
Edison, NJ
rider1454 at aol.com
25,141 Registered Members
186,614 Topics
89 D150 dually bed pro street project.
by NTOLERANCE
02/18/18 09:06 PM
78 4-speed Maxiwagon!
by Rhinodart
02/18/18 08:55 PM
Correct finish for leaf springs
by 76orangewagon
02/18/18 08:52 PM
Dodge Ram “ramside” truck parting out
by NTOLERANCE
02/18/18 08:49 PM
