Page 1 of 2 1 2 >
#2448314 - 02/07/18 10:51 PM Tri-Castle Nuts
cbusters Offline
Loc: Florida
69 Road Runner. working on the front suspension detailing and can not find any reference on the color of the Tri-Castle nuts used on the Ball Joints, Steering Arm, Idler Arm and Tie Rod Ends.
Natural?
Black Phosphate?
I believe I have the cotter pins figured out though.
#2448359 - 02/08/18 02:26 AM Re: Tri-Castle Nuts [Re: cbusters]
kentj340 Offline
Loc: Houston
See page 46, part number B-11486 with pentastar logo here:
http://www.amkproducts.com/Catalog_PDF/39-55.pdf
The S2 finish is "Phosphate & Oil (gray - black)", page 4 of the AMK catalog.
#2448387 - 02/08/18 07:24 AM Re: Tri-Castle Nuts [Re: cbusters]
cbusters Offline
Loc: Florida
Is AMK always on with their coatings? I have only gotten a few things from them in the past.
#2448417 - 02/08/18 08:39 AM Re: Tri-Castle Nuts [Re: cbusters]
njmopar Offline
Loc: Clinton, NJ
I recently installed these AMK nuts on my vehicle and in my opinion the shoulder where you would put the cotter pin through is too high. There was no way a regular cotter pin (like they one they send you) could be used. The hole in the shaft was barely showing. I had to torque a little tighter then spec and use a very thin cotter pin that I luckily had some stock of.
The parts being installed on were Moog with the exception of the pitman arm, which was original. The pitman arm was the worst with fit.
Edited by njmopar (02/08/18 08:40 AM)
#2448419 - 02/08/18 08:46 AM Re: Tri-Castle Nuts [Re: njmopar]
John Brown Offline
Loc: South Bend
Why wouldn't it have worked if the base of the nut was made a little thinner? shruggy
#2448448 - 02/08/18 09:41 AM Re: Tri-Castle Nuts [Re: njmopar]
71birdJ68 Offline
Loc: Morristown Tn.
Remember that this was on an assembly line where they did it as fast as they could. Torque with an air gun, and if the hole didn't line up, keep going till it did.
#2448478 - 02/08/18 10:31 AM Re: Tri-Castle Nuts [Re: 71birdJ68]
MOPARMIKE69 Offline
Loc: Nashville, TN
The new tri castle nuts are too tall. You either need to get originals or take a die grinder to the repops.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
#2448480 - 02/08/18 10:33 AM Re: Tri-Castle Nuts [Re: 71birdJ68]
ns1aar Offline
Loc: ontario calif
OEMs shoulder was not as thick.
#2448667 - 02/08/18 05:02 PM Re: Tri-Castle Nuts [Re: cbusters]
cbusters Offline
Loc: Florida
Lucky that I already have the nuts, I just need the coating information.
#2449386 - 02/09/18 11:28 PM Re: Tri-Castle Nuts [Re: cbusters]
fuelishnsilly Offline
Loc: Greenwood Lake, NY
I was going to say, can't you just grind down the bottom part of the castle nut giving you the clearance you'd need for getting the cotter pin through?
inherited a 69 roadrunner from my grand pop.
#2449440 - 02/10/18 08:28 AM Re: Tri-Castle Nuts [Re: fuelishnsilly]
njmopar Offline
Loc: Clinton, NJ
Yes, but then you risk removing the coating and mess with the bevel shown in the photo. If I didn't have the thinner cotter pins, would have had to grind.
#2449753 - 02/10/18 06:02 PM Re: Tri-Castle Nuts [Re: cbusters]
True, but at least that coating would be the bottom side of the nut and could be touched up with paint or even have RPM put on it to prevent rusting.
#2450111 - 02/11/18 12:32 PM Re: Tri-Castle Nuts [Re: cbusters]
UCUDANT Offline
Troll Hunter
Loc: New Mexico
#2450408 - 02/11/18 08:49 PM Re: Tri-Castle Nuts [Re: cbusters]
340cpe Offline
Loc: Pa.
When I installed aftermarket tie rod ends (moog) the ball stud was just a hair shorter than the oem and the hole was drilled lower in the stud compared to an oem tie rod. Could not get the cotter pin in with original nuts or reproduction amk’s. The moog nuts obviously fit fine but we’re not tri-castle.
#2450477 - 02/11/18 11:14 PM Re: Tri-Castle Nuts [Re: 340cpe]
ns1aar Offline
Loc: ontario calif
File out 3 of the 6 towers
#2451660 - 02/14/18 11:08 AM Re: Tri-Castle Nuts [Re: ns1aar]
hemi71x Offline
Loc: Rancho Cordova, California (Sa...
Not to hijack the original posters thread, but what are these castle nuts worth anyway?
I have never thrown anything on the ground, and left it there, when picking suspension parts, off cars since they invented U Pull It wrecking yards, around here, back in the early 1980's.
I probably have a storage container with about 30 pounds of castle nuts in it, and probably handfull's of those original 3 tower ones.
Think i should start selling them, to all the guys that are anal freaks for original castle nuts?
I remember when NS1AAR got a handfull of them from me, as we have known one another, for decades.
RF-4C Phantom 69-370 Zweibrucken, Germany
#2451923 - 02/14/18 09:03 PM Re: Tri-Castle Nuts [Re: cbusters]
cbusters Offline
Loc: Florida
Don't know if it is an anal freak thing, but it is one of those little things that get overlooked and they are kind of obvious when wrong. I have extras from past cars but they are not impossible to duplicate. If you look at them the have just had a mill take a pass and remove three of the points. The repop is just not quite right. It may be a GM or Ford part that the depth is wrong on. I imagine if you had a supply of them and had them plated correctly they would be easy to sell. Not having them would be like say a perfect breast enhancement and someone left off the nipple.
#2453399 - 02/18/18 09:00 AM Re: Tri-Castle Nuts [Re: cbusters]
UCUDANT Offline
Troll Hunter
Loc: New Mexico
...but you have to leave off 3 nipples to make a new replacement part look like an original
drumhit
#2453599 - 02/18/18 04:42 PM Re: Tri-Castle Nuts [Re: cbusters]
cbusters Offline
Loc: Florida
Three nipples on and three nipples off. Now modern looks vintage.
#2453774 - 02/18/18 11:57 PM Re: Tri-Castle Nuts [Re: hemi71x]
kentj340 Offline
Loc: Houston
You helped me out with a 9/16 "hex tri-slot nut" once upon a time. Thanks again!
Keep in mind that there are 7/16, 1/2 and 9/16 sizes, but only the 1/2" is reproduced AFAIK. You could command the entire intergalactic market for the other 2 sizes...
Page 1 of 2 1 2 >
25,743 Registered Members
193,027 Topics
This will tarnish the Patriots owner .....
by 70Challengerse
02/22/19 12:33 PM
Jegs/Summit Codes back out
by DusterKid
02/22/19 12:04 PM
Airtemp Infringing
by scatcity
02/22/19 11:32 AM
413 valve size
by als499
02/22/19 11:30 AM
