Re: Tri-Castle Nuts
[Re: cbusters]
#2448417
02/08/18 11:39 AM
02/08/18 11:39 AM
Posts: 1,331 Clinton, NJ
njmopar
Clinton, NJ
I recently installed these AMK nuts on my vehicle and in my opinion the shoulder where you would put the cotter pin through is too high. There was no way a regular cotter pin (like they one they send you) could be used. The hole in the shaft was barely showing. I had to torque a little tighter then spec and use a very thin cotter pin that I luckily had some stock of. The parts being installed on were Moog with the exception of the pitman arm, which was original. The pitman arm was the worst with fit.
Re: Tri-Castle Nuts
[Re: 71birdJ68]
#2448478
02/08/18 01:31 PM
02/08/18 01:31 PM
Posts: 2,632 Nashville, TN
MOPARMIKE69
Nashville, TN
The new tri castle nuts are too tall. You either need to get originals or take a die grinder to the repops.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
Re: Tri-Castle Nuts
[Re: cbusters]
#2449386
02/10/18 02:28 AM
02/10/18 02:28 AM
Posts: 356 Greenwood Lake, NY
fuelishnsilly
Greenwood Lake, NY
I was going to say, can't you just grind down the bottom part of the castle nut giving you the clearance you'd need for getting the cotter pin through?
inherited a 69 roadrunner from my grand pop.
Re: Tri-Castle Nuts
[Re: fuelishnsilly]
#2449440
02/10/18 11:28 AM
02/10/18 11:28 AM
njmopar
Clinton, NJ
I was going to say, can't you just grind down the bottom part of the castle nut giving you the clearance you'd need for getting the cotter pin through? Yes, but then you risk removing the coating and mess with the bevel shown in the photo. If I didn't have the thinner cotter pins, would have had to grind.
Re: Tri-Castle Nuts
[Re: cbusters]
#2449753
02/10/18 09:02 PM
02/10/18 09:02 PM
fuelishnsilly
Greenwood Lake, NY
True, but at least that coating would be the bottom side of the nut and could be touched up with paint or even have RPM put on it to prevent rusting.
Re: Tri-Castle Nuts
[Re: ns1aar]
#2451660
02/14/18 02:08 PM
02/14/18 02:08 PM
Posts: 5,357 Rancho Cordova, California (Sa...
hemi71x
Not to hijack the original posters thread, but what are these castle nuts worth anyway? I have never thrown anything on the ground, and left it there, when picking suspension parts, off cars since they invented U Pull It wrecking yards, around here, back in the early 1980's. I probably have a storage container with about 30 pounds of castle nuts in it, and probably handfull's of those original 3 tower ones. Think i should start selling them, to all the guys that are anal freaks for original castle nuts? I remember when NS1AAR got a handfull of them from me, as we have known one another, for decades.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Tri-Castle Nuts
[Re: hemi71x]
#2453774
02/19/18 02:57 AM
02/19/18 02:57 AM
Posts: 1,653 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Not to hijack the original posters thread, but what are these castle nuts worth anyway? I have never thrown anything on the ground, and left it there, when picking suspension parts, off cars since they invented U Pull It wrecking yards, around here, back in the early 1980's. I probably have a storage container with about 30 pounds of castle nuts in it, and probably handfull's of those original 3 tower ones. Think i should start selling them, to all the guys that are anal freaks for original castle nuts? I remember when NS1AAR got a handfull of them from me, as we have known one another, for decades. You helped me out with a 9/16 "hex tri-slot nut" once upon a time. Thanks again! Keep in mind that there are 7/16, 1/2 and 9/16 sizes, but only the 1/2" is reproduced AFAIK. You could command the entire intergalactic market for the other 2 sizes...
Re: Tri-Castle Nuts
[Re: kentj340]
#2453809
02/19/18 07:37 AM
02/19/18 07:37 AM
hemi71x
[/quote]You helped me out with a 9/16 "hex tri-slot nut" once upon a time. Thanks again!
Keep in mind that there are 7/16, 1/2 and 9/16 sizes, but only the 1/2" is reproduced AFAIK. You could command the entire intergalactic market for the other 2 sizes... [/quote]
Yes, i am aware of all the sizes. I've got them all in the storage container, out in the garage. I should start selling them off, on the Mopar related web sites, and ebay, and see what i can get for them.
